Pic's of Bearing # 7 (WOW was I lucky........)
Old Jan 22, 2005 | 01:19 PM
'02silver's Avatar
Do you think the light weight oil could of contributed to the scouring of the #7 bearing? I remember using the recommended 5w/30 oil my in Chevy Blazer and after a year or so of use I spun a bearing. I now always uses 10w30 in the Blazer and in the L.
Old Jan 22, 2005 | 01:21 PM
'02silver's Avatar
Old Jan 22, 2005 | 02:00 PM
bacamino's Avatar
your a lucky man
Old Jan 22, 2005 | 02:03 PM
bacamino's Avatar
dp
Old Jan 22, 2005 | 04:59 PM
Rob_02Lightning's Avatar
BTW
You can see the back of the bad Bearing is fine, no spinning occured YET.
It was clearly a journal / lack of oiling issue #*@#$@$#@($%@$
One with the flash on (the flash makes it look worse, it picks up every entire little scratch and intensifies it) the backs were fine
Old Jan 22, 2005 | 07:52 PM
fastdailydriver's Avatar
hey rob, when your motor goes to machine shop what are they going to do for the oil passages so you dont have that same problem ? do all builders enlarge the oil passages to the journals as standard practice? also congrats on your motor sal does all my work and its ALL GOOD
Old Jan 22, 2005 | 11:26 PM
03F15054FX4's Avatar
Rob,
Definitely invest in a better grade oil. Try running AMSoil or Royal purple 5w-30. The 5w20 motorcraft has terrible visoscity.
If you're the researching type, http://theoildrop.server101.com/cgi/ultimatebb.cgi
Old Jan 23, 2005 | 02:42 AM
Nathan's Avatar
In general if you're running your truck hard, consider having an oil analysis done every oil change or two. It can pick up an increased accumulation of metals and contaminants and may provide an early warning of engine wear. They can sometimes even discern what part is suffering abuse based on the differing metallurgy of different components.
Of course, just because the analysis comes back OK doesn't mean you dont have problems. However, if the analysis shows elevated levels of certain components it's a good early warning sign that something might be going south on the express.
Old Jan 23, 2005 | 04:00 AM
Red03SVT's Avatar
nathan: I have never heard of this before?? is it relatively inexpensive? and where would you get this done?
-Mike
Old Jan 23, 2005 | 09:43 AM
01 XLT Sport's Avatar
-Mike
Blackstone Laboratories is a great place for oil analysis. It cost $20 for a standard test plus $1.50 or so for mailing it in to them. Here is a link to their websites FAQ. Look around they have some good information.
What is nice is you can get a free kit, I have one waiting in the garage for the next oil change. They send it to you for free and don’t charge you until you send it back for analysis.
Blackstone Lab’s
Old Jan 23, 2005 | 10:36 AM
Excellent info Sport, AND WELL WORTH IT
