Pinging w/ 6# pulley
Old Jan 20, 2005 | 10:34 PM
OrlandoBolt's Avatar
Hi,
I own a 01L and I just recently installed a 6# pulley on it. I have also purchased a chip tuner to reflash my chip. My truck is stock otherwise except for a cat back system.
The tuner module comes with a default program for pulley upgrades but when I flashed the computer with it I get pinging around 4,000 RPM.
I have colder plugs and a cooler stat going in but I was wondering if anyone else has experienced a pinging problem with the added boost and if you did anything to get rid of it besides octane booster. I do not feel like purchasing octane booster for every tank of gas as I drive the truck often.
Is there anything I can do or should I drop down to a 4# pulley? I have tried retarding the timing. Will raising the A/F ratio help?
Old Jan 20, 2005 | 10:47 PM
l-menace's Avatar
or dropping the timing!
Old Jan 20, 2005 | 11:02 PM
Blown347Hatch's Avatar
If it's the Predator, use the pulley tune, drop the timing by 10% and add fuel by 10%. This usually stops the pinging. You have 93 octane in the tank, right?
Old Jan 21, 2005 | 08:49 AM
ByByBird's Avatar
You bought a "chip tuner" to reflash you chip? You mean you bought a Predator to reflash you computer right?
Did you purchase the Pred from a vendor that does custom tunes via email? Or did you by it from ebay or some other big mail order company?
My advise for now is to subtract 10% timing and add 10% fuel for now..This might not even totally cure it. The tune that come in the Pred SUCKS.. I ran it for a bit with no problems but others have blown up motors running it.
GET A CUSTOM TUNE...ASAP!!!!!
P.S I gained 20rwhp and 30rwtq with a custom tune over the Pred pulley tune.
Old Jan 21, 2005 | 09:02 AM
Thanks for the help guys!
I had already brought the timing down 10% I will add the fuel. Does anyone have any recomendations as to a good shop to purchase a custom tune for the predator?
Old Jan 21, 2005 | 09:30 AM
Disintegr8or's Avatar
I would be interested in this information as well. Thanks!
Old Jan 21, 2005 | 05:20 PM
Flash2211's Avatar
Going thru the same thing.
Bought my predator from rpm outlet, they're still working on a custom tune (6 tunes so far)....still pinging.
I'm looking for someone to custom tune it for me, suggest you do the same.
Old Jan 21, 2005 | 06:14 PM
02Thunder's Avatar
REM down in Margate, FL tunes with Diablo if my memory serves me right. Tim at REM seems to be a pretty good tuner.
That said, I run SCT. So take my advice with a grain of salt.
joe
Old Jan 21, 2005 | 06:24 PM
afchad's Avatar
There are a few good tuners here in Tampa that can help you out. With a stock bottom end and a 6lb pulley.....I would definitely go with a custom dyno tune.
Old Jan 21, 2005 | 10:49 PM
LXguy's Avatar
Maybe try taking the tuner out and uninstalling the tune?
A buddy of mine ran a 6#er for a long time with no tuning and had no problems.
In any case, its worth a shot.
Steve
Old Jan 22, 2005 | 07:49 AM
ByByBird's Avatar
James @ RWTD can send you a spot on tune via EMAIL. I used JLP for my orig dyno tune and all my retunes for mods.
Old Jan 22, 2005 | 08:11 AM
Oneevil01's Avatar
What does pinging sound like .... when i got my 01 last week i think the dealer filled it up with cheap gas because it would make a noise (kinda hard to describe) around 3500 rpm ... It wasnt too loud but i heard it . Ever since getting the old gas out i cant recall hearing anything, Do you think my truck was pinging ? And if not give me an idea of what it sounds like so i can look out for it whenever i mod the truck
thanks
shane
Old Jan 22, 2005 | 11:23 AM
FLOORD U's Avatar
a BB in a hubcap is a close description.you can hear it best with your windows up and the radio off.
if you hear it...lift
Old Jan 22, 2005 | 12:06 PM
Red03SVT's Avatar
that's a good description ^^^. also, like dropping a BB or a small marble into a tin can.
Old Jan 22, 2005 | 12:44 PM
Rob_02Lightning's Avatar
Welcome to the family OrlandoBolt
Awesome choice of Mods, CONGRATS
A lightning is a very unique vehicle, so much so that a simple bad tank of gas, wrong tune, clogged fuel filter or injector, can AND HAS TONS OF TIMES resulted in bye bye motor. So tunning them is 100% more important to do correctly than prob any other vehicle in the world.
We should never buy a chip or tuner from walmart, (RPM outlet = Same) You buy them from a Lightning Tuner that can give you a true custom tune for your truck, your fuel, your octane, your elevation, your driving habbits, and your mods.
Diablo is known for aggressive off the shelf custom tunes,
I tried MANY myself a few years back on my L (NFG)
I believe many say to use the NON Pulley tune that came with the Predator (yes even know you have a pulley) if the +10% -10% trick doesn't work.
We have many supporting Vendors here that can help you.
As mentioned Johnny Lightning tunes Predators
and Sal of PSP does also.
Supporting Vendors are here https://www.f150online.com/vendors.cfm
Congrats, Welcome, AND BE CAREFUL,
do not let it detonate, it's extremely dangerous, more so than you can possibaly imagine
