Methnol Injection???
Does anyone run methnol/alcohol injection on their truck, if not then why? Seems to be a really good idea. Cooler intake temps and more boost with out detonation. Thanks!
Originally posted by promodlightning
Ive run it for a while. Gave me 3#s of boost and stripped rotors on 2 blowers. Enabled me to run a more aggressive tune on the street. All in all, It was a worthwhile mod.
Sir!!! Your gonna miss out on your BEAUTY SLEEP sir!!!
Originally posted by 35thPony
A lot of people of people have tried it, but it is nearly impossible to evenly distribute it, it would require you to fab a manifold to distribute it correctly...
All the teflon on your rotor packs will be gone. As far as gaining power, I made 618 rwhp on pump gas with it. Ive seen it strip rotor packs on 1 KB and 3 Eatons. Stripped rotors arent bad though. I ran without the teflon coating and couldnt feel a difference. You could try increasinf the lubricant mix to 2 teaspoons and that may help.
No one has made a succesful set up yet, that is all I am saying... Also it is not the same as nitrous... That N2O does not act like methanol anyways... I have seen 5 L's on the dyno try it and none worked... And like the other poster said, if you get it working will, have fun with rotors.
Ok, so it strips the teflon off the rotors, what is the exact result of this and add 2 teaspoons of lube to what? the methnol? But what if you run more water to dilute the methnol, say 75% water 25% methnol, it will still kill the rotors??? also would this void the factory warranty?? Thanks guys I really appreciate it!
I have a water/methanol injection on my mustang. Unfortunately it did not help the car make more power. This is likely due to the fact I run a blow through carb setup and it didn't atomize fast enough. I then found a puddle in my carb box, and noticed it dripping out my blow off valve. I may try more testing using a different nozzle location, but I'm still not certain it will help me. I don't run pump gas in this car anyway.
I have often thought of trying it on the lightning, but since it appears to cause the teflon to come off I may skip it. I would assume it would void your factory warranty, but it seems to depend on your relationship with the dealer, and your ability to remove the kit without a trace.
Good luck,
greg
Good luck,
greg
Thanks! Well, I guess I ll have to just research more. the reason i brought it up is that my friend just installed meth inj on a turbo camaro and saw 3.5 psi and 43rwhp. But thanks everyone, any other feel free to chime in!
