Stupid Testing
Old Jan 17, 2005 | 02:05 PM
TampaBlack99's Avatar
Stupid Testing
http://fordtruckworld.tenmagazines.c...aid=1980&sid=2
Unfortunately, the truck did not want to cooperate and in this situation, we had a poor idle after the first few dyno runs and our results were inconclusive. Nevertheless, we gathered several other dyno runs that AEM has produced in recent days and found that the system delivered an average of 19.6 hp and 13.5 lbs.-ft. of torque to the rear wheels of these vehicles.
Duh, our test did'nt work so we just took there word.
Old Jan 18, 2005 | 05:34 AM
clonetek's Avatar
They must have been too busy with Lisa Sparks to get the truck running right.. LOL
Old Jan 18, 2005 | 07:31 AM
ema100c's Avatar
Ford truck world should have contacted me!
I installed that system on my 2001 L and did before and after dyno runs. Mine picked up 15HP and about 8 or 9ft/lbs of torque. The only thing was that they seem to derive the added power by letting more air go by the MAF sensor into the motor thus leaning it out a bit. The I.D. of the tube where the MAF gets installed is 100mm. This is 10mm wider than the stock MAF housing.
My L's factory PCM tune is already on the lean side according to people on here who looked at the dyno sheets I posted. But Sal said that this was not uncommon and the stock tunes vary.
My dyno run after the AEM was installed showed the final A/F ration being about .25 to .5 higher than stock.
I have taken the AEM off for now until I decide what to do with it.
I guess I need a dyno tune where the A/F table can be adjusted to compensate for the increased amount of air going into the motor.
Eric
Old Jan 18, 2005 | 09:38 AM
Yup, keep that sucker off your truck till it's tuned for the pipe.
Old Jan 18, 2005 | 10:03 AM
02Thunder's Avatar
Are you referring to Sparxxx or the AEM piece???
joe
Old Jan 18, 2005 | 10:45 AM
You feeling better for drink'in this Thursday?
Isn't she tuned for several pipes at once?
Old Jan 18, 2005 | 11:00 AM
02Thunder's Avatar
I am still home sick bro, hope to be back to work tomorrow, daytime TV sucks...
j.
Old Jan 18, 2005 | 11:05 AM
watching soaps and opra
Old Jan 18, 2005 | 12:05 PM
Mart Man 03 L's Avatar
I wonder if the idle problem was caused by incorrect TPS voltage. Seem to remember some folks having this trouble when swapping intakes.
Old Jan 18, 2005 | 12:37 PM
ema100c's Avatar
Something else must have been wrong with that girl's L. After installing the AEM I didn't have any idle or running problems. Other than the lean part! My L ran like normal.
Old Jan 18, 2005 | 02:42 PM
Konig's Avatar
Where is the puke smiley?
Old Jan 18, 2005 | 06:30 PM
BigSVT's Avatar
did ya'll notice that the caption for one of the pictures said it was a 1999 Lightning and then on the dyno sheets it said 2004 ford lightning.
