how to polish something?
Old Jan 15, 2005 | 11:39 AM
TampaBlack99's Avatar
STOP NOW, before you lose your mind.
Old Jan 15, 2005 | 12:24 PM
ra1nmakr's Avatar
i like the painted blower. i might do something like that in the future.
Old Jan 15, 2005 | 07:54 PM
hyvltge's Avatar
Originally posted by 00Bolt
hyvoltage....
hey bud, if you dont mind... could you kinda give me a run down on step by step and what exact materials I will need?
looks like I will need a dremil and a polish end for a drill.... any other tools....???
i was gonna say email me... but might as well put it on here for everyone to see
thanks alot!!!
I used high temp paint and high temp clear. Believe it or not I used a file on the Ford and SVT on the front to knock it down and get it smooth. Then I used a 9 volt battery as a sanding block and sanded it going finer and finer with the grit, finishing with 2000, 2500 and 3000. Then I topped it off with some polishing compound. I purchased a sanding / polishing kit from Sears and used it on my Dremel type to to knock the rough stuff off of the ribs. A nice sharp file then helps smooth it out. Then before paint, I masked the ribs with 1/8 masking tape (purchased from a auto paint supply store). Then for the front letters, I dabbed just a small amount of vaseline on them so the paint would not stick as well and be easier to remove. Then once it was painted I CAREFULLY used a razor blade to "cut" the paint off of the letters.
Hope this all is clear. Let me know if you have questions or need help.
Old Jan 16, 2005 | 09:20 AM
KB ZILLA's Avatar
Listen to Tampa or you will become a polishing fool ...and fiberglass expert
