Oil in intake elimination question.......
Old Jan 6, 2005 | 09:34 AM
Blown347Hatch's Avatar
If I install the breathers on each valve cover, how much blow-by are you guys seeing as a result of having no PCV?
In years past, when I have done this, there has always been SOME blow-by, which varies engine-to-engine, and wear and other factors as well, but I just don't want that smell permeating the truck.
Thanks.
Old Jan 6, 2005 | 10:01 AM
fullboogie's Avatar
I've seen a lot of concern about the PCV system on these engines, mainly over oil intrusion into the intake system. Has anyone tried using breathers, eliminating the PCV system, and using a vaccum pump to eliminate crankcase pressure? Seems like it might be a good alternative.
Old Jan 6, 2005 | 10:15 AM
That was exactly the set-up I was referring to in my post.
I want to know what people are experiencing regarding blow-by.
Old Jan 6, 2005 | 10:26 AM
wydopnthrtl's Avatar
I've heard some guys are seeing considerable spray. Really it would depend alot on how a guy drives, oil temps, and types of oil (to a small degree).
IMO.. a daily driver should not be using breathers. But on a toy truck / racer I'd think it to be ok.
(stock setup w/a seperator on mine)
Rich
Old Jan 6, 2005 | 10:33 AM
Thanks Rich. I always welcome and respect your input.
Old Jan 6, 2005 | 10:40 AM
fullboogie's Avatar
On my buddy's 9-second Cuda, he uses an old air pump from a Caddy that was originally for the air ride suspension. He reversed the polarity of the wires and turned it into a crankcase vacuum pump. Cheap, and it works.
Old Jan 6, 2005 | 10:46 AM
I have a vacuum pump on the Mustang. I would like to stay on the actual question of blow-by mist and odor if breathers are used. Thanks.
Old Jan 6, 2005 | 11:43 AM
TrackBeast's Avatar
For a daily driver, what is the best location for the seperator and which seperator is recommended?
Has anybody done a write up on this?
TB
Old Jan 6, 2005 | 11:54 AM
No problem,
A guy could always put a foam sleeve over the out side and clean it every once in a while.
Even though my truck now is pretty much parked I'm choosing to stick with the stock setup and seperator. Mostly because I want to have the ability to drive it anywhere anytime.
Old Jan 6, 2005 | 12:33 PM
brahmus's Avatar
rich, i have the same seperator you do but i recently changed my plenum and found oil in there.. so is it doing you any good?
