Torque specs?
Old Jan 6, 2005 | 11:26 AM
BradsL's Avatar
Torque specs?
Hi, I am new at this site. Many of you may know me over at SVTPerformance.com. I am Slider over there. Here is my question.
I am going to be taking my S/C and intercooler out tonight to clean and prep for the oil separator. I know the torque specs on putting th S/C back on through the How-too section. Does anyone know or have a printable sheet that has the torque specs for putting the intercooler back on?
Also, what do you clean the intercooler with? I heard carb cleaner will do it. Is there anything I need to protect while spraying?
Thanks for you help in advance.
Old Jan 6, 2005 | 12:18 PM
hyvltge's Avatar
Here is some useful info:
http://azloc.com/forum/viewthread.php?tid=774
The intercooler is torqued with the supercharger bolts upon install. They are a little bit of a bear to get to, but just take your time. If you use carb cleaner to clean it out you will be fine. You will need 6 + cans depending on how dirty it is. The whole job is very straight forward. Good luck!
Old Jan 6, 2005 | 01:06 PM
BradsL's Avatar
Thank you!
