Side view mirror directional
Old Jan 5, 2005 | 06:11 PM
FatherLarry's Avatar
The directional bulb on the side view mirror on the passenger side of my Lightning has burned out. Does anyone know how the mirror comes apart so I can replace it. I think the back cover snaps off, but I don't want to force it. I have ordered a shop manual as it will come in handy.
Old Jan 5, 2005 | 07:23 PM
Don's Bolt's Avatar
You tilt the glass part of the mirror all the way down. The if you look inside you will see two little tabs inside. Take a verry small screw driver and that will relaease the two tabs.
WARNING be verry carefull after you release the two tabs. There are two small tabs on the bottom that you have to be carefull with
Old Jan 5, 2005 | 08:39 PM
Don's Bolt,
Thanks so much! That really helps.
Old Jan 6, 2005 | 10:43 PM
Thumbs up
Job done! Don, you're advice was right on...thanks again.
