Boost gauge???
Old Jan 3, 2005 | 07:48 AM
Jody007's Avatar
Boost gauge???
I'm trying to figure out what the deal is on my 01 lightning. At first the intercooler wasn't acting right, (did not bubble all the time), then found a hose from my s/c had been disconnected. (it had suction to it - a red hose, connected to a metal cylinder on the right hand side of the s/c)
The boost gauge now indicates 0 when I turn the truck off. It used to show VAC. When I turn the truck on the needle used go back down, then rose after I turned it off. I replaced the intercooler pump relay and not much has changed.
So,
1. the intercooler doesn't bubble like I fugure it supposed to...
2. What is it that makes the boost guage function ? Vaccuum ? Charge?
I dont know. Any suggestions? Anyone had similar difficulties?
If you can tell me anything that you may have learned about this kind of issue please E-mail me jlublanezki@yahoo.com
Old Jan 3, 2005 | 08:21 AM
brain bypass's Avatar
the boost gauge is mechanical, meaning it has a vacuum hose run to it. it should sit at 0 when the truck is off.
