retractable rear window?
Old Dec 30, 2004 | 11:33 AM
flamedlightning's Avatar
Has anyone seen a electric retractable rear window for the F150's? My sliding window is vibrating like something awful and I want to get rid of it.
Old Dec 30, 2004 | 11:47 AM
Derek94's Avatar
I'd be interested also if you mean a full up and down rear window
Later
Old Dec 30, 2004 | 01:49 PM
WaveBlaster785's Avatar
Company called Breezer makes one I believe.
Old Dec 30, 2004 | 02:12 PM
l-menace's Avatar
the heritage Harley Davidson models had a sliding rear window
Old Jan 2, 2005 | 10:11 AM
Grimace's Avatar
I bought a power slider from cr laurance. I have yet to put it in though, too lazy.
Old Jan 2, 2005 | 11:03 AM
mattadams's Avatar
Not sure what you mean by "retractable". Breezer makes a window you can take completely out. C.R. Laurence makes a power slider, I've got it installed in my beast, its awesome.
FYI, Any Fords that come with the power slider, actually have the C.R. Laurence unit. My switch is mounted in my seat.
Old Jan 2, 2005 | 11:12 AM
coopersunc's Avatar
I assume you did the intall, yes? What was the cost? Cheaper than buying from Ford?
Looks great.
Old Jan 2, 2005 | 11:16 AM
mattadams's Avatar
Cooper, my body shop did the install of the window itself, because they had to take the window out anyways (we were repainting the entire truck), but I did the wiring and the motor installastion. Installation took about 25 minutes, which was aided because I already had a fuse block back there for power, and the interior was already apart for reasons mentioned already.
Yes, it was cheaper then from Ford. Forget where Ig ot it from, some sunroof place actually.
Old Jan 2, 2005 | 11:26 AM
Grimace's Avatar
Matt, that is a pretty cool place to put the switch. I was actually going to try to put mine in the drivers door, behind the window switches.
Old Jan 3, 2005 | 08:55 AM
I was looking for something that goes up and down. Can you post some pics of the power slider?
Old Jan 3, 2005 | 09:01 AM
mattadams's Avatar
flamed, if you want something like that, it'll have to be custom. Because of how the back seat mounts etc. you'd basically have to add on to the back wall behind the cab, etc. in order to have a channel for it to go down into. not very easy.
The C.R. Laurence power slider looks almost identical to the factory sliding window, with the exception of the finger opener thingy. Here's some pics.
