Wiring guru's....
Old Jan 1, 2005 | 07:03 PM
0light1's Avatar
Wiring guru's....
I hard wire my radar detector via the overhead console. When I turn my lights on it turns off. I know this has to do with the auto diming feature. I'm not aware of any other way to wire it.
Anyone have suggestions??
I have a whistler pro-73
thanks,
-Rich
Old Jan 1, 2005 | 08:06 PM
ILLINI-SVT's Avatar
When you turn the lights on, the auto dim decreases the voltage into the temp display, which is less than the detector needs. You can either run a new power wire up there, or splice that one into a different power source, but to splice it elsewhere, you'd need the wiring diaqgrams to find out where the harness plugs into.
Old Jan 1, 2005 | 09:18 PM
0light1's Avatar
That's what I was afraid of.
Thanks for the info..
Old Jan 1, 2005 | 09:51 PM
Krix330cic(NJ)'s Avatar
Get a fuse tap, and get power off your fuse block.
Old Jan 1, 2005 | 10:34 PM
Frank S's Avatar
Like stated above, go straight to the fuse panel, preferably to a constant power source. Also make sure to use a fusible link in case of a power surge you wont burn your truck up.
Old Jan 1, 2005 | 10:47 PM
0light1's Avatar
Sounds like a fix to me!!
Thanks a bunch. I will get started on this first thing in the morning.
Thanks,
-Rich
Old Jan 2, 2005 | 04:02 AM
buckn4sty's Avatar
I think this is what you will need to get it sorted out. I think I used the wh/lb. The full sized version is
here.
Old Jan 2, 2005 | 11:40 AM
0light1's Avatar
Got it...
Borrowing a pic from ROB02 I updated to add the fuse i used which is key on power only.
Thanks all!
and yes I used an inline fuse.
Old Jan 2, 2005 | 06:26 PM
SVT_KY's Avatar
I think you musta grabbed the wrong wires. The voltage
on mine is constant regardless of the light switch position.
Here's the best write up ... Madhouse's
Hard Wired Radar Detector in F150
Old Jan 2, 2005 | 10:12 PM
0light1's Avatar
That's exactly the link I used. white w\b was the only hot wire available there. I'm sure it's my detector, it must require a bit more voltage or something like that.
oh well it works geat now and only took me 15min. to do.
