Apten, 4lb, 6lb???
Old Jan 1, 2005 | 11:38 AM
Edward Goodell's Avatar
Apten, 4lb, 6lb???
Hello everyone. I was just curious about those three different thngs. I have currently a 4lb lower with most common bolt ons. I was dyno'ed at jdm at 401 to the wheels and 499 pounds torque on street tune. I can't afford headers and mid pipes yet but i was wondering if getting the 6lb pulley put on would wind up being the same difference if i just get the eaton ported. I realize that a 6lb without headers is dangerous with out a dyno tune. But is getting the supercharger ported just as dangerous with out headers. I would obviously keep the 4lb on if i get the port job. and/ or put the 6lb on and keep the supercharger as is. Any opions would be appreciated.
Old Jan 1, 2005 | 11:56 AM
l-menace's Avatar
6# with Apten Tune - = 433rwhp, 522rwtrq
(on a dyno tune, Street tune only (think conservative tune))
PSP
Stock exhaust.
Old Jan 1, 2005 | 12:15 PM
yea i had a single program chip but i just purchased the 4 bank chip from jdm and can't wait for the spring so i can race on the the race tune. That makes me nervous with all that boost you have on stock exhaust but hey good luck lol. I don't think i'm that daring lol
Old Jan 1, 2005 | 12:23 PM
l-menace's Avatar
i go to the track twice a year and put about 4000 miles on it a year.
I'm seriously looking at getting shorties.
There are so many companies that make them for th 5.4L
regular 5.4 shorties will fit the "L"
Old Jan 1, 2005 | 03:14 PM
D Davis's Avatar
and when you "Search" you find out shorties are a waist of money and labor for what you gain.
DO IT right or leave it alone, but hey thats just my opinion
Old Jan 1, 2005 | 04:45 PM
Fast Gator's Avatar
Don't waste your hard earned money, long tubes or nothing.
I was 483rwhp on the Apten port job with a 6lb lower and a 1lb upper, long tubes, and a bunch of other bolt=ons
Before and after the Apten
Old Jan 2, 2005 | 12:19 AM
kerno's Avatar
Porting the blower should be your next move. Putting a 6# on a stock blower can make enough heat to cause engine failure.
Old Jan 2, 2005 | 12:45 AM
Blown5Pnt4's Avatar
I'm planning on doin something similar, only goin with a 4# lower, 2# upper, and Ported blower....but I'm also adding LTs and High Flows.
Old Jan 2, 2005 | 07:24 AM
wydopnthrtl's Avatar
Porting the blower is an excellent bang for the buck. It has a cooler discharge temp, higher output psi, and I speculate it takes less power consumption to achieve both of those.
BTW: It does lean out your burn a little. As long as your tune is "conservitive" to begin with you won't need to worry. Just keep an eye on the plugs.
Rich
