Tachometer wire white/pink?
Old Dec 28, 2004 | 01:05 PM
kevalson's Avatar
I am installing a remote starter in a 2001 Ford Lighting.
The wiring diagrams I find say it is a white/pink on the main wiring harness that comes through the firewall just to the left of the brake pedal.
In a nutshell, I can't find it.
I have looked at every wire and the closest I found was a white/red, which I tested and that was not it.
The instructions also said it could be found at the connections to the PCM.
Where is that located?
Can anyone help me out?
Thanks in advance.
Kevin
Old Dec 28, 2004 | 04:16 PM
kevalson's Avatar
Perhaps someone has the wiring diagram for this?
Old Dec 28, 2004 | 05:37 PM
LTNBOLT's Avatar
Zoom in on this and you can read it.
You might have to save it first.
Old Dec 28, 2004 | 06:34 PM
kevalson's Avatar
Well that helps more than anything else.
Thanks.
According to this, it is pin # 52 on the wire control harness, though I think any of the 8 would do.
I would have liked to tap into a wire under the dash somewhere instead, but I cannot find the white/pink wire there.
So I will run a wire from piun 52 of the harness and that will work.
Thank you for your help.
Kevin
