Factory tune restore on the predator?
Old Dec 18, 2004 | 09:41 AM
svtpete's Avatar
Unhappy Factory tune restore on the predator?
I restored my factory tune today and now when i went to put my new custom tune on instead of reading "Custom Tune" it now gives me a list of options. Did I loose my custome tune? if not how do i get it back.
Old Dec 18, 2004 | 09:58 AM
LightningTuner's Avatar
If you did an actual "restore", that means you reset the Predator, as if it was never used. If you had a custom tune on it, it's gone. You just need to re-upload the custom tune from your PC that was e-mailed to you by your tuner.
Old Dec 18, 2004 | 10:14 AM
svtpete's Avatar
Thanks i did restore the factory tune and im sure it reset everything. The bad thing is i had to send my predator in to jlp for a new tune for the 5# pulley i installed last night. This is the tune i erased. Im using a mac and i donot believe that there is a program for it but my friend will probably let me use his computer. Do u think jlp will send me a new one?
Old Dec 18, 2004 | 10:19 AM
I'm sure JLP has your tune on file. I get some MAC customers send me Preds to load tunes on for the same reason. I was told that there is actually a program for the MAC, that lets you run a windows program. I think it's called Vware or something like that. Maybe look into that first so you don't have mail it in again. Hope this helps.
Old Dec 18, 2004 | 10:34 AM
svtpete's Avatar
Is there a tune on the predator right now that will be ok to use while im waiting for atune from jlp?
Old Dec 18, 2004 | 10:59 AM
NO! Do NOT use any of the factory loaded tunes. You will be safer driving the truck on the stock tune than with any of the loaded ones.
Old Dec 18, 2004 | 11:32 AM
St Louis Lightning's Avatar
Connectix Virtual PC will work on the MAC's. Looking at Apples website, I don't see any current MAC's with serial ports though. Maybe a USB to Serial interface would work.
-Mark
Old Dec 20, 2004 | 11:21 AM
svtpete's Avatar
Hey Sal i have not been able to get in touch with JLP. What do u charge for tunes?
Old Dec 20, 2004 | 11:23 AM
If you did not buy the Pred from us, it's $100 for the first tune, and then $30 for each tune after that. I don't charge for "adjustments" to tunes if any are needed.
