eaton rebuild?
Old Dec 17, 2004 | 01:25 PM
00rsvtl's Avatar
Angry eaton rebuild?
bee hearing a bearing going out.just replaced the alternator witch has it's bearings going out.gave the blower a little spin while the belt was off.fell a little binding.got it all back to gether and started it up.clearly hear a cold bearing (or something inside).is there any sort of rebuild kit for our eatons? or should i take it off and take it to stegimeier?anyone want to chime in?
Old Dec 17, 2004 | 01:31 PM
easterisland's Avatar
magnuson does repairs
Old Dec 17, 2004 | 02:29 PM
Derek94's Avatar
Also, i've noticed lately on cold mornings, my blower has been making some type of bearing noises. When its low 30's high 20's it seems to do it until it warms up. I need to take the belt off and give it a spin, check the oil etc. I also have apten port job done to it, which was done a couple months ago. Maybe its just the cold tho
Old Dec 17, 2004 | 07:12 PM
Suavy's Avatar
dumb question but have you checked your blower gear box oil level? Also one thing to remember the grease in the rear bearings is a special grease and is hard to get. Further it should be measured for longivity. Here is a pic of what's inside the snout of your eaton.
Old Dec 17, 2004 | 07:45 PM
LightninMike's Avatar
i have the same and hear the same, i sent mine back to Stegimeier and he said mine was fine
i guess well see what happens
Old Dec 17, 2004 | 08:42 PM
Don's Bolt's Avatar
Don't and I repeat don't send it to Magnuson
I would much rather you send it to Magnum Powers for service
http://www.magnumpowers.com/
I have no idea why Eaton still uses Nagnuson as a authorized repair facility
Old Dec 18, 2004 | 06:42 AM
00rsvtl's Avatar
i will call steigemier today.i had them port the blower about 2 months ago.reinstalled with fresh gear oil.if i have anyone serive it i would take it to them.mainly because they are about 20 min from me.
Old Dec 18, 2004 | 03:49 PM
TampaBlack99's Avatar
What the hell does http://www.magnumpowers.com/ have anything to do with servicing an Eaton?
http://magnusonproducts.com/ did a great job in rebuilding my Eaton.
Old Dec 18, 2004 | 05:04 PM
Suavy's Avatar
MP has the talent to service the Eaton. It's not a question if they can service the Eaton the question is weather or not MP would even want to rebuild an Eaton.
Tampa, I can service an Eaton and do work on blowers in my area. Take a look at the pic. I just posted that is an Eaton snout that I worked on.
I don't offer my services cuz I am not a supporting vendor. However, those of you who know me well know I can and have e-mailed me for part No. and or directions.
Merry Christmas,
Suavy :santa:
Old Dec 28, 2004 | 01:07 PM
00rsvtl's Avatar
got the blower off and took it to steig. it is a warped case.they said most of the lightning blowers are warping after being ported.they had not been checking the clerances and machining the case until recently when they realized this was a problem.they took it apart and showed me were the rotors had been rubbing the case.they said they will take care of it
Old Dec 28, 2004 | 03:07 PM
Stl01SVT's Avatar
My first ported blower seized from lack of clearance. I went to Stiegemeier's shop and we examined at least 10-12 stock blowers and they all showed signs of the rotor/case contact. Stieg's machined in extra clearance on my second ported supercharger. They used my supercharger as a test to see if the increased clearance would still build and hold boost. Well, it works great, I'm seeing 14-15lbs of boost with just a 4 lb lower.
Old Dec 28, 2004 | 06:34 PM
00rsvtl's Avatar
did it just lock up on you without any noise? mine was fine when i put it back on.once it started to get cold is when i started to hear it rubbing.it did not get any better as the blower warmed up.over the past few weeks it got worse.
Old Dec 28, 2004 | 06:43 PM
Stl01SVT's Avatar
My supercharger would ocassionally make noise on startup. It failed at the track after a run. As soon as I let off the gas it was making a horrible noise. By the time I got back to the pits and popped the hood I knew it was the supercharger. I turned the truck off and let it sit for about 15 minutes. When I tried to restart, the supercharger was locked up so tight that the engine wouldn't even turn over.
If you want to check out the supercharger, stop by sometime. I'm in O'Fallon.
Old Dec 28, 2004 | 08:28 PM
00rsvtl's Avatar
guess i may have done the right thing and tear the blower off.i was sure it was a bearing and was going to take off the nose.i had just put the blower back on and did not want to take it off again.mainly because it took forever to get a new set of bolts to mount the blower.then come to find out the everthing is coated in oil again i needt to fix the drivers side some how.so much oil is being pulled in the boot that it is going in the vacume like and leaking out the boost acctuator (A QUESTION I HAD IN A PREVIOUS POST).i will have to drop in sometime.
Old Dec 28, 2004 | 08:48 PM
Stl01SVT's Avatar
I've reused my stock blower bolts, twice.
