eaton rebuild?
Old Dec 28, 2004 | 08:55 PM
Derek94's Avatar
my supercharger had been making noise on startup also, i installed a c&l intake today and spun the blower,and it seemed to have a rough spot in the rotation, if i recall correctly the blower used to just spin freely w/ out any tight spots. Does this mean my blower case has warped and i need to get more clearance? is this going to be a constant problem? If so, ill be pretty dissapointed with the apten port, as i had no idea it would do this. Any ideas?
Old Dec 28, 2004 | 09:02 PM
Stl01SVT's Avatar
Derek, try tightening the 2 intake bolts closest to the firewall first, then the next two, then finally the front two.
When I pulled the intake off my seized blower the two bolts closest to the firewall were looser than the other four bolts.
Old Dec 28, 2004 | 09:14 PM
Stl01SVT's Avatar
The front edge of my failed Eaton's intake had heated up and sank down .020. When I installed the upper intake on my new blower. I tightened the back four bolts first, and there was probably about .020 gap on the front bolt holes to the supercharger. I installed shim washers to bridge this gap.
Hope this helps.
-Mike
Old Dec 28, 2004 | 09:34 PM
Derek94's Avatar
good thinkin. i try to tighten them down evenly, but maybe i didnt. It seemed a lot worse today than it did last week. I'll have to loosen the bolts and try your method, then again the damage could already be done. Any ideas to how much it would cost to have it checked out etc? Id rather just upgrade the blower if it becomes expensive. Then again there may not be anything wrong with it.
Old Dec 28, 2004 | 09:44 PM
00rsvtl's Avatar
Originally posted by Stl01SVT
I've reused my stock blower bolts, twice.
i am goint to reuse mine again.it took me 6.....yes 6 weeks to get the new set of bolts in.already have enough trouble with this truck
Old Dec 28, 2004 | 11:07 PM
St Louis Lightning's Avatar
Nice to hear about another Ofallon truck.. I'm over by the TR Hughes ballpark - where are you?
-Mark
Old Dec 29, 2004 | 06:05 AM
00rsvtl's Avatar
-Mark
i live off of bryan road.on the street directly behind the firestation.
Old Dec 29, 2004 | 10:29 AM
Stl01SVT's Avatar
I've seen you a few times early in the morning. I live behind Walgreens.
Old Dec 29, 2004 | 10:33 AM
Stl01SVT's Avatar
Originally posted by Derek94 Any ideas to how much it would cost to have it checked out etc? Id rather just upgrade the blower if it becomes expensive. Then again there may not be anything wrong with it. [/B]
Bob Stiegemeier would charge very little to increase your rotor/case clearance and clean up any damage.
Stiegemeiers
636-949-2275
Old Dec 29, 2004 | 02:25 PM
Derek94's Avatar
Well took the belt off today, gave the blower a spin, spun perfectly, maybe it was hitting the phenolic spacer i installed at the time? I now think its one of the idler pullies in the front thats going out, any good products to replace those two with? Thanks!
Old Dec 29, 2004 | 06:15 PM
00rsvtl's Avatar
Stiegemeiers
636-949-2275
have not heard back from them yet.but twhen i went up there they said they did not check the clearance and would take care of
Old Dec 29, 2004 | 06:19 PM
00rsvtl's Avatar
i see 2 other red l's around.you for sure and another one,i see around troy/winfeild plus a silver l alot and sometimes here...................anyone?
