Shocks
Old Dec 16, 2004 | 10:15 AM
FunFord's Avatar
Registered User
Shocks
I recently lowered my truck with the Ground Force 1-2'' drop kit. The ride is not to bad, but a little rough for my taste. What are some good shocks for my set-up? I mainly want it to ride a little smoother. Thank you!
Old Dec 16, 2004 | 10:29 AM
brain bypass's Avatar
i dropped mine 1.75" in the front with Ruslow springs. i used the hotchkiss bilsteins. i think they are slightly underdampened (is that a word?) but should work well with the eibach springs.
did you change the bumpstops also?
Old Dec 17, 2004 | 01:13 AM
FunFord's Avatar
Registered User
Yes! the new kit came with bumpstops.
Old Dec 17, 2004 | 01:21 AM
Tim Skelton's Avatar
I don't think that anything will smooth out the ride. In my experience, the springs are what is causing the harshness. Looser shocks will just make the handling worse without really giving you a softer ride.
YMMV.
Old Dec 17, 2004 | 10:33 AM
FunFord's Avatar
Registered User
Oh, then what kind of springs would soften it up a little?
Old Dec 17, 2004 | 03:52 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Eibachs will provide the Buick-like 'ride' you seek. Just don't enthusiastically toss it into a corner because it will respond accordingly and with less than desireable results.
