Cold weather starts
Originally posted by fast1
Cool. I've got an LS1 question. My dad dyno'd his 2000 TransAm about a month ago. It's stock, just a K&N Filter. The numbers were good, but you could hear some slight pinging. I was alarmed. My dad got all defensive and said all "newer" cars run right on the edge. So some pinging at WOT is normal. What do you think?
shelpdoggSVT- Didn't mean to highjack your thread. I agree with the other guys, sounds like a battery problem.
-Sly
Thanks for all of the replies fellas....I guess I will price both yellow and red and then see which one I need...only have a stereo right now...no other devices that pull any power to speak of. The stereo is only pushing around 800W.
As far as the thread hijacks......it's kewl........we can talk about anything you guys want....chicks, trucks, a good sandwich.....
Pull up a chair...it's a free for all b!tches!!!
Originally posted by badazz99l
lol only 800W
-Sly
lol only 800W
-Sly
That's only one amp.....can't wait until I get the second one in.I'm thinking yellow top Optima.......
Originally posted by Robert Francis
Fast1 - if you can "hear" any kind of "pinging" - I'd be a little nervous.
I'm not that familar with the 2000 TransAm model, but I can tell you that only a very small number of vehicles over the years have been designed from the factory to "run on the edge," because of warranty concerns and variability in the design and build process. "Pinging" can come from a lot of sources, and sometimes isn't as dangerous or detrimental as "detonation" which is an entirely different thing. As noted before, timing has a lot to do with it - and because of inherent varibilites in the build process of all components can vary somewhat from vehicle to vehicle - bottom line being if you put two of the same vehicles under the same conditions such as WOT - one might "ping" amd one might not. One common cause over the years of "pinging" is carbon buildup in the combustion chambers, which frequently only shows up under high load or WOT conditions. Also, quality of fuel has a lot to do with it. Something you might suggest to your dad to try is put in 93 octane fuel and see if the pinging goes away.
PS: I'm a "dad" too and sometimes we're awfully hard to convince, ha, ha
Originally posted by IronmanSTL
I agree, sounds like your battery...
I have had our L for 3 weeks now,
Originally, I was going to drive it in the winter.
I started it one day at -28 celcius last week. The supercharger was not impressed, it moaned for a good 20 seconds, I imagine it stopped once oil circulated it it a little more.
It's now in the warmth of my garage till Spring.
So when you southern guys think its cold out, think how lucky you are.
Shouldn't our low compression motors be easier to start than regular compression motors when it gets cold out?
Iron
Iron
On another note, you FL guys need to quit complaining about the winter in FL
