JLP intake installation
Today I received my intake from JLP. I have a few questions, first- it came with two sheet metal screws, I used one to hold down the screen but I dont know where the other one goes? Second- does the box just sit in there, becuase the directions did'nt say anything about sucuring but it is a little loose? Third- has anyone ever noticed how jagged and rough the hole is in the inner fender where the air comes from? It looks like something a kid did with a torch. That kind of dissapointed me to find something like this on a $30,000.00 truck. Thank you!
The only sheet metal screw I got with mine was to hold the mesh lid onto the air box. I don't remember if the box was bolted down or if it just sat in there but I just went out to the truck and the box felt like it was bolted down. While I was out there, I also noticed that jagged opening in the fender. I didn't see that before but it does look crappy. You should call JLP to get some more answers.
Thank you everyone! I called JLP and one screw is for the screen, and the other is for the tubing for the ram air which I did'nt buy. Also they said it just sits in there, no bolting required.
When I got mine it did not fit exactly right. I had to put a 3/4" block underneath it to make it line up with the C & L intake...
Well, now that the box lines up with the intake, the top rubs the hood. GRRR... 20 minutes with a cut-off wheel and the box is now short enough to clear the hood...
Well, after it had been in for a week or so, I started hearing a squeak...
It seems that the box was moving around a bit when the engine torqued over, causing the squeak...
So, a piece of 1/4" thick rubber mat under and around the box and it is now quiet.
When I contacted JLP about the fit, they said they had not had any complaints from other '04 owners.
So, I guess mine is the odd one out there... Story of my life !!!
