what is wrong with my pinion angle
Originally posted by svt_2004
here is how my pinion angle looks now, but i am getting a vibration between, 30 mph and 50 mph
what should i do? i already have shims to correct the angle in there
I havent been driving it! My truck is in the garage, its been off the road for a few months now, I have never driven it with the positive angle. The truck only has 5000 miles on it
The early springs have five leaves, like the 2003/2004's. The late ones are slightly stiffer and taller to bring the GVWR up to over 6000 pounds, putting it in a different tax and fuel category.
Your pinion angle looks pretty good from the photo. Are you sure your vibration is not wheel balance?
I think you're going to just have to change the angle a little deeper. If you're at about a -1 angle now, buy a different shim to shift it to a -3. The extra couple of degrees should make enough of a difference to eliminate the vibration.
