Lightning -> F-150 Frame Swap
Hello:
I have a chance to buy a 02 (I believe) Lightning, thats been rolled over for DIRT cheap, if it wasn't this cheap, I wouldn't consider it.
The frame is not damaged, but the cab is. Anyways, I was thinking of buying another F-150, and swapping over the cabs. Both are my cars, so no harm done, right?
I've seen how to take the cab off a truck, and doesn't seem too involved. My buddy has a workshop, and I can buy the body lift (the ones that are extended arms off of cherry pickers).
I've ALWAYS wanted an extended cab'd truck. My Ranger is regular cab, and I HATE trying to fit people inside. I hate it when I try to carry things, like my books, I don't have any room for another person or anything else, unless I keep it outside, and risk them getting wet. Now the question is, can I swap an extended cab on the Lightning's frame?
What about the wiring? Can I use the stock 4.6L wiring on it? I've read that the 2V 5.4L people can throw on the Lightning supercharger, MAF sensor, and re-chip the ECU, and they don't need anything else. Can I do the same with the 4.6L? What about the security system (forgot the abreviation) built into the ECU?
Would there be a difference between the cabs of a V6 and a V8?
And just for kicks, could an Expedition chassis fit on a Lightning frame?
Thanks for all the input!
-Tahleel
The frame is not damaged, but the cab is. Anyways, I was thinking of buying another F-150, and swapping over the cabs. Both are my cars, so no harm done, right? I've seen how to take the cab off a truck, and doesn't seem too involved. My buddy has a workshop, and I can buy the body lift (the ones that are extended arms off of cherry pickers).
-Tahleel
Originally posted by lightninquick
a guy on nloc.net goes by the call name madferrasiti he ha done this already. check out his website i think he might be a vendor there
good luck
good luck
I found this page:
http://www.madenterprise.com/f150.htm
Or are you talking about the frame swap?
-Tahleel
The frame length is different between the extended cab and standard cab trucks. You could certainly swap the Lightning powertrain into the e-cab chassis, but you can't put the e-cab on the Lightning frame.
