Trans Filter
Old Dec 1, 2004 | 12:43 AM
FunFord's Avatar
Registered User
Trans Filter
Today I ordered a FTVB and Moroso pan. What filter do I need and where can I get it? Also what transmission fluid do I need to use, and how much?
Old Dec 1, 2004 | 05:10 AM
jarmstro's Avatar
Post Re: Trans Filter
Stock filter for the Moroso pan and get DEXTRON III/MERCON trans fluid and does not have to be Motorcraft either.
Buy at least 12qts. add 7qts. start truck and with foot on brake go through each gear. Check level and add as needed but don't over fill.
The Moroso pan is an easy install.
Old Dec 1, 2004 | 08:29 AM
Dan SS2471's Avatar
And make sure you use a torque wrench. Good luck. You won't be disappointed.
Old Dec 1, 2004 | 09:45 AM
FunFord's Avatar
Registered User
I thought you had to get a bigger filter, like the one with the pan 4X4 pan. Also do I need a in/lbs trq. wrench or ft/lbs?
Old Dec 1, 2004 | 10:21 AM
bobver's Avatar
I did not use the stock filter with the Moroso pan. I believe I got the filter p/n from the Moroso web site. The filter I used has a longer neck.
Old Dec 1, 2004 | 10:30 AM
JeffsLightning's Avatar
I used the stock filter. Interesting that bobver used a different one
Old Dec 1, 2004 | 10:46 AM
FunFord's Avatar
Registered User
Has everything been ok so far? Do I need to get a filter from Ford or can it be bought at any autoparts store?
Old Dec 1, 2004 | 11:03 AM
bobver's Avatar
Per the Moroso web site....
Transmission Pan, Ford Lightning E40D/4R100, 3.642 inch depth. Use Motorcraft Filter Part No, FT113
That's the filter I used.
Old Dec 1, 2004 | 11:16 AM
FunFord's Avatar
Registered User
Old Dec 1, 2004 | 11:18 AM
FunFord's Avatar
Registered User
Thank you!
Old Dec 1, 2004 | 11:52 AM
That's the same filter as stock.... Ford number YC3Z7A098AA
Old Dec 1, 2004 | 12:39 PM
FunFord's Avatar
Registered User
I just bought fluid and a FT-113 filter from Ford.
Old Dec 1, 2004 | 01:07 PM
jarmstro's Avatar
Yes you do need an inch torque wrench.
The 4x4 filter neck is too long for the Moroso pan, I know cause I used my 4x4 filter and it dimpled the Moroso pan.
USE STOCK FILTER you bought and enjoy.
Old Dec 2, 2004 | 12:56 AM
FunFord's Avatar
Registered User
Thank you for all your help everyone!
