Detonation source: Brisk GOR-17
Old Nov 28, 2004 | 01:57 PM
Master Of Pain's Avatar
Well, it appears that my Brisk was kicking my butt this whole time. I was chasing my tail regarding the strange source of my observed detonation irregardless of timing or A/F ratio.
Obligatory pictures:
Can you identify which hole is the traditional "lean" hole?
Old Nov 28, 2004 | 02:14 PM
Blown347Hatch's Avatar
Pics didn't upload?
Old Nov 28, 2004 | 02:23 PM
chimshady1's Avatar
How much boost u runnin?
Old Nov 28, 2004 | 02:27 PM
14 lbs. The Brisk were WAY too hot. I installed TR-6's that exhibit zero detonation issues.
Old Nov 28, 2004 | 02:45 PM
SLVRLTNG's Avatar
That's why I suggested checking your plugs. Here's what mine did first trip down the track a few weeks ago..... 14lbs of boost and 40 degrees temp outside. melted 4 of them
Old Nov 28, 2004 | 03:26 PM
Casey02L's Avatar
It looks like the Brisk plugs are the wrong heat range for our motors as cross referenced.
BTW; the last hole on the drivers side is the most commonly lean hole. Probably followed closely by the second to last hole on the drivers side.
Old Nov 28, 2004 | 04:36 PM
Struck in AZ's Avatar
Weren't these things all the rage like three months ago...I could've sworn they were being touted as the wonder plugs.
Old Nov 28, 2004 | 04:48 PM
Redlightn 02's Avatar
Tampablack99 made this chart, hope he dosen't mind me sharing but it might help out someone deciding on plugs for the amount of boost they're running.
Old Nov 28, 2004 | 09:41 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Old Nov 28, 2004 | 10:20 PM
JeffsLightning's Avatar
The GOR-15's might be a better choice....I would stick with what has been proven though...
Old Nov 30, 2004 | 02:58 AM
don presby's Avatar
TTT
Old Nov 30, 2004 | 06:37 AM
Rob_02Lightning's Avatar
Originally posted by Casey02L
...the last hole on the drivers side is the most commonly lean hole. Probably followed closely by the second to last hole on the drivers side.
I'd agree 100%,
Both times I had a plug issue, it was the 3rd back DS on both ocassions, along with the 4th back on 1 of those ocassions.
Of course it's always the two hardest Plugs (@$%)@$@_$^@)$%
Love the design of these Brisk Plugs, but it does seem some are having issues with them ??? Glad to hear the TR-6's got you back to normal Master Of Pain
Old Nov 30, 2004 | 08:40 PM
Suavy's Avatar
One thing you need to do also is run a compression check now that you melted plugs. I melted 4 plugs on the dyno a couple of months ago and when I removed No. 8 plug there was a tad bit of alum on the thread. When I went to put the plug back in it spun the threads. I pulled the heads only to find out that the lobes where the spark plug comes threw was melted half way.
Detonation causes the electrode to melt in most cases then the spark seeks the path of least resistance.
Also remember that the piece of electrode that burned off has to go somewhere, right! Mine went between the piston and the cylinder wall.
Suavy
Old Dec 1, 2004 | 02:34 AM
blowfish's Avatar
Master of pain, the plug with all the oil on the threads and burnt oil on the tip. What hole is it out of?
