Factory Fuel Pump Limit?
Old Nov 27, 2004 | 05:32 PM
Casey02L's Avatar
What is the HP limit of the factory fuel pumps? I made 514 on the dyno, and it was showing 60 pounds without it leaning out any on the top.
I have 50# injectors if that makes a difference, and plan to run about 18~19 pounds of KB boost.
Old Nov 27, 2004 | 09:54 PM
chimshady1's Avatar
I read in muscle mustang and fast fords a little upwards of 500.October 2002 issue(35 hot lightning tips)
Old Nov 28, 2004 | 09:00 AM
Dave02's Avatar
Re: Factory Fuel Pump Limit?
you're kidding right?
Old Nov 28, 2004 | 10:05 AM
Rob_02Lightning's Avatar
I made 501/615 the last time I dyno'd, 100% STOCK FUEL SYSTEM, and my AF was 10.4 at the LEANEST part of WOT
No fuel problems here "YET"
When I go built motor this winter, I will be running
@ 100 HP more, and will have to see what the Dyno shows then ???
Old Nov 28, 2004 | 10:14 AM
Casey02L's Avatar
See; Like Robs you gotta wonder. His were doing just fine, but I think I will swap mine just for the added insurance.
Rob; does your nitrous kit tie into the fuel pump wiring any?
Old Nov 28, 2004 | 10:16 AM
Casey02L's Avatar
Re: Re: Factory Fuel Pump Limit?
Nope; I plan to try and get my stock block into the 10's. It'll either make it, or split trying
Old Nov 28, 2004 | 11:13 AM
Dave02's Avatar
Re: Re: Re: Factory Fuel Pump Limit?
You scared me!
As long as you know you're near the edge!
But I would get bigger pumps, just to eliminate that chance of that making you lean
