Front bumper cover
Old Nov 28, 2004 | 01:06 AM
FunFord's Avatar
Registered User
Front bumper cover
Is there any way to adjust the front bumper cover? Mine sits a little low on the drivers side, and it just bugs me. Thanks?
Old Nov 28, 2004 | 04:28 AM
madferraristi's Avatar
Yes, the brackets are slotted and allow about 1/2" vertical movement on each side.
Old Nov 28, 2004 | 10:50 AM
FunFord's Avatar
Registered User
Is it just two bolts that I loosen or do I loosen all the bolts holding on the bumper.
Old Nov 28, 2004 | 11:24 AM
You should only need to loosen the two, one above the other, on each side. Try loosening only the two on the low side first with a jack under the bumper and see if it will go up (or down). It you can raise it enough to get it level, you're done.
I wanted the gap between my bumper and the enderside of the grille closed up so I removed the brackets and lengthened the slots. Looks much better now.
