My Rearend was Shot...
Old Nov 24, 2004 | 08:06 PM
LightningToGo's Avatar
Has any of you needed your rearend rebuilt? I just had mine rebuilt. They installed a new carrier assembly, bearings and races. I guess this was caused due to drag racing with slicks.
Old Nov 24, 2004 | 08:25 PM
fomocofan's Avatar
Yes, it is very common. The rear has clutches in it that wear.
You could just replace the clutch pack, but most shops replace the whole carrier, it's easier.
Old Nov 24, 2004 | 08:30 PM
min150mph's Avatar
Yes, I did about 10K miles ago. Clutches were gone. Could barely get the other side to spin.
Old Nov 24, 2004 | 09:11 PM
Master Of Pain's Avatar
Is there a kit for the rear end with beefier parts like the Monster In A Box kit?
Old Nov 24, 2004 | 09:31 PM
Neal's Avatar
Cool
HI!... Yes, I rebuilt mine last year. Totally destroyed it. Worn clutches, cracked carrier and chipped/broken gears. I guess the 9.75 rearend is not as strong as FORD thinks it is LOL!
Old Nov 24, 2004 | 09:34 PM
Neal's Avatar
Cool
HI!... More :
Old Nov 25, 2004 | 09:54 AM
RED 92's Avatar
ditto,
or something more than posts that confirm that your rear end was also shot (Neal ) ...... How about some info on the rebuild ??? Did you go to the ford dealer for the posi rebuild kit for the 9.75 , did you search for any upgrade parts, ....helpful hints on the rebuild etc etc...
I have 5K on my truck and it peg legged once but it was around a corner and the weight was shifted to the drivers side in second gear..... Im working one wearing it out at the track with slicks......my line lock is slowing down this process
Old Nov 25, 2004 | 11:18 AM
Tim Skelton's Avatar
Re: My Rearend was Shot...
Originally posted by LightningToGo
. . . I guess this was caused due to drag racing with slacks.
But the chicks dig them.
Old Nov 25, 2004 | 11:51 AM
superfords's Avatar
somehow I knew something like that was coming.
Old Nov 25, 2004 | 12:01 PM
2000L's Avatar
Had to rebuild mine a week ago. It had about 15 launches on Nittos and the rest on F1's. Its 2000 44000 miles.
Old Nov 25, 2004 | 02:32 PM
promodlightning's Avatar
I thought Detroit Locker was supposed to come out with a beefier posi for us. Or you could just run a spool and not even worry about the posi going bad.
Old Nov 25, 2004 | 03:04 PM
fomocofan's Avatar
Currently Eaton and Auburn make posi's for the 9.75, I don't know of a Detroit Locker or spool for it.
Old Nov 25, 2004 | 03:10 PM
chimshady1's Avatar
Couldnt the gears be welded together for a posi setup(of coars race only)I seen it done on junkyard wars once.lol..
Old Nov 26, 2004 | 12:14 AM
TrackBeast's Avatar
What does this mean?
I have a rattle ucoming from underneath the truck. Got it checked and I'm told that my pinion bearings are totally shot.
The driveshaft moves up and down (tons of slack). Apparently, this is really dangerous and I guess the driveshaft could come off...
What do I likely need to repair this? Rear ends (at least on cars) are what I least understand.
TB
Old Dec 2, 2004 | 11:09 AM
RED 92's Avatar
Re: Re: My Rearend was Shot...
Tim nice pants....... hey hows your 9.75 holding up with your road racing ? Is mobile 1 and friction modifyer the only upgrade you have done ? Are peg legs a problem exiting corners?
