OK, guys I'm crazy...M112 question.
Old Nov 22, 2004 | 04:05 PM
MadMav's Avatar
I'm about to mix Ford and Chevy. A company has made a sheetmetal intake to put an Eaton M-112 on an Impala SS LT1 motor. I am eventually going to go with a Blowzilla, but I was wondering if the 112 will support a 383 stoker with an 8.4:1 compression ratio? Will I have to overboost it, or will life be fine for a few months? Thanks for the help.
Mav
Old Nov 22, 2004 | 04:20 PM
MadMav's Avatar
I'm sorry guys, I could have swore that I had posted here before. My bad. Not the right way to go for the first post is it? Been a member for a while, just never got the chance to say or ask anything important.
Just consider this question to be the lead in for the Lightning addiction.
Mav
Old Nov 22, 2004 | 04:30 PM
thundergod's Avatar
depends on how free flowing your 383 is. If it has killer heads,big valves, headers, and a nice intake you may have to spin the hell out of it to make boost. If it is a basically stock LT1 it should work just fine.
Old Nov 22, 2004 | 04:31 PM
ByByBird's Avatar
There are more effecient blowers to use but it will work fine on your set up.
I'm assuming you will be intercooled? If not then I'd say your wasting you time with a M112.
Old Nov 22, 2004 | 04:37 PM
LightningTuner's Avatar
IMO, an M112 is too small for a motor that size. But it also depends on WHAT M112 they are using. There is no "generic" Eaton M112. If they are using one from an 03 Cobra or Jaguar, that would be better than a Lightning unit.
Old Nov 22, 2004 | 04:39 PM
MadMav's Avatar
Ouch, you guys are killing me. But thanks for the help!
Heads are stock iron ported 2.02/1.60 valves
Flow #s are
Lift Intake Exhaust
100 62 49
200 125 107
300 182 151
400 224 173
500 248 184
600 245 190
they were ported for the stock LT1 bottom end and an ATI P1 setup. Adding the cubes and a larger cam might make it more difficult I see.
Has nobody ran the M112 on a stroked 5.4?
Mav
Old Nov 22, 2004 | 04:57 PM
Don's Bolt's Avatar
Why not a Whipple???
http://www.whipplesuperchargers.com/...sp?ProdID=1139
Old Nov 22, 2004 | 05:08 PM
MadMav's Avatar
Well, as far as I'm aware, they don't make one that will bolt onto the Lightning, or in the same location as the M112. Do they?
Mav
Old Nov 22, 2004 | 06:18 PM
Redlightn 02's Avatar
Mav
In the works as we speak.
Old Nov 23, 2004 | 03:07 AM
MadMav's Avatar
Redlightn 02,
Thanks, I have read that it has been in the works for over a year now. How soon is this happening?
I would rather go Whipple if I had the choice, but I was wondering if the M112 would last for 6-12 months while I saved up? Thanks,
Mav
