What is the recommended jack weight for our trucks?
Old Nov 22, 2004 | 12:00 AM
TampaBlack99's Avatar
3 or 4 tons to safely lift the front of the vehicle?
Old Nov 22, 2004 | 12:40 AM
Redlightn 02's Avatar
Four is better than three in this case I would think, it's your life it's worth it. How much more are the four ton ones?
Old Nov 22, 2004 | 01:05 AM
PaulSmith's Avatar
You can get a 4 Ton @ Sears for about $129-,.. lower if they are having a sale.
Old Nov 22, 2004 | 02:06 AM
fastfordf150's Avatar
Does anyone make a lightweight 4 ton floorjack? ie Harbor Freight...?
Old Nov 22, 2004 | 07:13 AM
jarmstro's Avatar
I hope you meant 4000lbs not 4 tons.
Sears makes a 4000lb aluminum jack that weighs approximately 37lbs. nice jack, around $199 but if you are a member of the Sears price club you can get it for $169 when they put it on sale or when Sears has their Blue Light special.
I use mine on my Super Duty also.
Old Nov 22, 2004 | 07:24 AM
Blown5Pnt4's Avatar
I use a heavy as hell 6ton(yes 12000lbs+) floor jack.....but it works great, lifts the thing without even breaking a sweat.
Old Nov 22, 2004 | 07:44 AM
Sharpshooter's Avatar
I use the aluminum craftsman jack. Its only rated for 2 tons.
It lifts the truck, but seems like it does struggle to lift the front end. I figured that its great for changing the rear tires out, because the rear of the truck is lighter then the front end.
I don't think I would trust any jack with my life, I think you should always have jack stands set up before going underneath.
Old Nov 22, 2004 | 07:45 AM
SVT_KY's Avatar
I have the Harbor Freight Aluminum one and it's fine ...
5,000 / 2 = 2,500 pounds (Lifting front or rear ...) Or
you can lift one side at a time and jackstand it ... I have
noticed jacking on the cross member in the front has a
tendency to bend it.
Old Nov 22, 2004 | 09:40 AM
I take it this is what I want.
http://www.harborfreight.com/cpi/cta...temnumber=2672
How many pounds in a ton?
Old Nov 22, 2004 | 09:43 AM
Nevermind, 2 Tons = 4,000 lbs.
Old Nov 22, 2004 | 01:04 PM
jarmstro's Avatar
Post
Same price as K-Mart/Sears craftman 4000lb jack.
Old Nov 22, 2004 | 02:17 PM
Yup, think I'm just gonna buy this one after Christmas.
http://www.sears.com/sr/javasr/produ...ab=des#tablink
Old Nov 22, 2004 | 02:19 PM
Dman25's Avatar
i use a 2 1/2 ton jack, and it works just fine. so thats a 5000lb jack for a vehilce that weighs under 5000lb, and ur never lifting all that weight at once, at most probably about 3500lb.
Old Nov 22, 2004 | 04:07 PM
SVT_KY's Avatar
Noooooooo ... don't buy that one!!! Believe me on this ... You
will hate it.... It takes a bazillion strokes to raise anything.
Sure.... the first stroke is quick to the take up point, but
all the rest are mini-strokes......
Trust us on this ... Get the racing jack ...
Click here ...
Old Nov 22, 2004 | 04:30 PM
soap's Avatar
Click here ...
Don't those release super fast.....thus the "racing" designation.
Why not just go with the Craftsman jack.......
4000# Aluminum Jack
--Joe
