Lightning "hooting" between 2000-2400 RPM??
Old Nov 11, 2004 | 05:42 PM
LXguy's Avatar
Hey All:
I test drove a Lightning this week. Once it was warmed up, it would "hoot" between 2000 and 2400 RPMs. It sounds like it is coming from the glove box.
It did it both while driving, and if I parked the truck and revved it to 2100 RPMs.
Any ideas?
Thanks!
Steve
Old Nov 11, 2004 | 05:47 PM
KCinAZ's Avatar
Probably a loose heat shield or something thats vibrating and giving off a strange sound at certain rpms.
Old Nov 11, 2004 | 07:10 PM
LIGHTNINROD's Avatar
Heat shield does 'sound' likely but maybe an exhaust leak from the right bank?
Dan
Old Nov 12, 2004 | 01:08 AM
Tim Skelton's Avatar
Re: Lightning "hooting" between 2000-2400 RPM??
Originally posted by LXguy
. . . It sounds like it is coming from the glove box. . .
Did you look in the glove box?
Old Nov 12, 2004 | 10:49 AM
BMWBig6's Avatar
Re: Re: Lightning "hooting" between 2000-2400 RPM??
LMAO Tim, you saved that one!
Old Nov 12, 2004 | 11:51 AM
wydopnthrtl's Avatar
Back 10 years ago I had a 4.6L t-bird. It did just about like you are describing. Turned out to be a faulty idle air valve. I cleaned it perfectly and it did'nt help. Replaced it and that did the trick.
Rich
Old Apr 11, 2005 | 03:57 PM
LXguy's Avatar
This is an old post, but I thought I would post the solution in case anyone searched.
It turned out that the orifice in the heater hose has dislodged from its clamp. The dealer put on a new heater hose and voila, fixed.
Steve
Old Apr 11, 2005 | 05:01 PM
fullboogie's Avatar
I'm just trying to figure out WTF is going on with that picture above!
Old Apr 11, 2005 | 05:10 PM
Bootbox's Avatar
If I remember correctly that guy was an illegal alien they were trying to smuggle over the border. Or something.
Old Apr 11, 2005 | 10:46 PM
gbgary's Avatar
lol. blond white guys are coming into the country at an alarming rate.
Old Apr 12, 2005 | 08:49 PM
Marc Carignan's Avatar
I'm really glad you posted this because I've had that exact problem since a week after I had bought my L brand new last spring. I've been gone too much and otherwise been too lazy to check it out so I just learned to live with the slight "hooting whistle" at those RPM's. I'm gonna try a new heater hose when I get home.
Old Apr 13, 2005 | 02:17 PM
LXguy's Avatar
Good Luck!
Steve
