Question about knock, not your normal question
Old Apr 13, 2005 | 02:11 PM
03WHITELIGHTNIN's Avatar
I just read an old thread over at NLOC, and a guy on there said that you can have a "rich" knock. It is this possible?
Discuss.
Old Apr 13, 2005 | 02:46 PM
MHMCGILL's Avatar
Re: Question about knock, not your normal question
Discuss.
Yes!! It's when Ed McMahon is knocking on your door telling you that you've won a million.
Old Apr 13, 2005 | 03:09 PM
curmudgen's Avatar
Or when you dump so much fuel in the crankcase, the crank hits it. Which will also blow the bearings.
And you will have a definte knock.
Old Apr 13, 2005 | 03:23 PM
Re: Re: Question about knock, not your normal question
Good one.
Let me try this again. Can you have too much fuel, and too little timing, cause a rich knock? If so what would the numbers roughly be?
Old Apr 13, 2005 | 03:27 PM
RED 92's Avatar
When running rich, the evaporative effect of excess fuel tends to absorb combustion chamber heat, which will thus lead to lower combustion temperatures and help reduce detonation/pre-ignition/knocking........
Retardation, is most likely the reason for the debate over at NLOC.
I can think of no thermodynamic reason that a 5.4L with A/F less than stoich AFR , RICH would knock...(with reasonable amount of ignition timing and intake temps).
I'll go read the debate.
whats the thread title ?
Old Apr 13, 2005 | 03:58 PM
I was thinking the same thing. This is not a debate, just an old thread that I pulled up, and was just wondering if anybody else had any input. The reason I went a found this thread, is because the thread starter is a friend, who got a custom tune from a supporting vendor, the vendor said it was very rich, with only 15-16 degrees of timing (he checked the timing, but didn’t have access to a wideband). His truck detonated, so he switched back to the predator pulley tune, and has not detonated since. The reason I am asking this is I run a 4lb lower, and I have a winter tune with 16 degrees of timing locked with an 11.0-11.2 a/f ratio, and my truck detonates in 3rd gear. I notice it when it is warm outside, and the truck is heat soaked. So I think I am going to try my summer tune and see what the deal is. Never had a problem with my summer tune, just the winter tune, which I received a couple of months ago. Also, I run Denso's IT22's, and the fuel filter was changed about 2500 miles ago. I will link you to the thread if you want me to. click here
Old Apr 13, 2005 | 04:36 PM
RED 92's Avatar
03WHITELIGHTNIN
Have the tuner check that tune, if there are no other factors involved the timing and A/F (if the curve is correct) are not the reasons for your detonation.
