Few questions about MP
Old Nov 2, 2004 | 11:31 AM
00Bolt's Avatar
i read somewhere were someone gained about 14 over their eaton... so does that mean about 40hp over stock eaton??
Old Nov 2, 2004 | 02:28 PM
Casey02L's Avatar
Look around and check; there will probably be some used ones for you to try. Lotta people switching from MP to KB's
Old Nov 2, 2004 | 02:47 PM
lightninquick's Avatar
the power lands somewhere between the ported eaton and the kb. the power is great and my et's are better
Old Nov 2, 2004 | 03:33 PM
SILVERLIGHTNING's Avatar
Arrow 65/70 gain
I switched from a 2 pound lower stock eaton, to the MP with a four pound lower. Went from 435/522 to 501/591.
View all images from this gallery
FF
Old Nov 2, 2004 | 03:41 PM
00Bolt's Avatar
thats what i wanted to hear.... so other than the pulley and the MP... did you do anything else??
what are all your mods
Old Nov 3, 2004 | 10:22 AM
Cool TOONED BY JDM
We ran out of injectors and had to go with the 50s. The larger injectors actually made less power.
Dropped the Flip Chip and went with the SCT 9100.
Still running the stock long block...
JLP ram air, 90mm MAS, Throttle Body, Ported & Extrude Honed upper plenum, Phenolic Spacer, 4# Lower pulley(21 PSI BOOST), Full Exhaust, E-Fan & Pump, Injectors, SCT Custom Dyno Tuned at JDM.
FF
Old Nov 5, 2004 | 12:02 AM
Casey02L's Avatar
Re: 65/70 gain
FF
Nice STD numbers
Old Nov 5, 2004 | 11:53 AM
l-menace's Avatar
Re: Re: 65/70 gain
Nice STD numbers
A little bias are we?
Old Nov 5, 2004 | 03:23 PM
LatemodelRacer2's Avatar
Re: Re: Re: 65/70 gain
Not really there are more going from magnums to kbs than you think....I only had mine 2 weeks
Old Nov 6, 2004 | 10:39 AM
Casey02L's Avatar
Bias maybe.....
Maybe speaking the truth to help fellow L members from making the same mistake.....
You decide
Old Nov 6, 2004 | 02:31 PM
JimIII@jdm's Avatar
Former Sponsor
Re: Re: 65/70 gain
Nice STD numbers
They were dynoed before and after STD so the gains are relevant, pointing out they are STD numbers isnt.
JimIII
Old Nov 6, 2004 | 02:59 PM
03WHITELIGHTNIN's Avatar
Old Nov 6, 2004 | 05:25 PM
Casey02L's Avatar
JimIII
Pointing out they are STD is to make sure the rest of the community realizes how the #'s will compare to there SAE numbers which will be lower
Old Nov 6, 2004 | 06:30 PM
casey i feel your pain, i also bought the magnum with visions of 500 hp. i can only say good things about the magnum after actual racing with all the other blowers.
but the initial wtf feeling was painful when i did'nt have 500
put all the blowers together at the track and the magnum sits high and proud. i can vouch for that
Old Nov 6, 2004 | 06:40 PM
JimIII@jdm's Avatar
Former Sponsor
I understand that when a power goal isnt met it is quite upsetting. Dealing with these vehicles on a daily basis you will see that so often. However there are trucks out there making that kind of power so it can be done. There are too many variables to even list that can be different about 2 trucks that have the same blower. Its all the matter of getting what you need besides the supercharger to get there. We had 3 Magnum trucks this Friday at JDM day that all ran 11's all day(11.90s-11.80s) stock block. There is still power to be unlocked in these trucks too. When my truck is ready for it there will be a Magnum sitting on top.
JimIII@JDM
