lines bolted to rear??
Old Oct 31, 2004 | 08:06 PM
BLUE N BLOWN's Avatar
while on my way to atco last week i noticed a rattle under my truck when i took off from a light or when i went over bumps. me and a couple buddys pull into a lot jack it up and see that theres a black cable from the pass side of the truck that bolts to the top of the pumpkin. the bolt was missing and this cable and bracket were rubbing against my driveshaft causing that noise. no biggie all the lines were connected and what not so my buddy taped everything up temporarily so i could run. today we went and bolted the lines back up to the top of the rear and i noticed that black cable i think it has something to do with the break was rubbing against my passenger side shock. i also noticed that there was alot of tension o nthis cable. if anyone knows what cable im talking about is it supposed to go around the shock? or between the shock?? i think that when the suspension compressed it put tension on that cable causing it to pull fron the top of the rear. does anyone have a pic of this and how the cable is routed?? sorry for the bad explanation but i wasnt really sure how else to word it. thanks guys
Old Nov 1, 2004 | 09:18 AM
superfords's Avatar
sounds like your parking brake cable.
