C & L Intake Plenum & Tuning????
Old Oct 22, 2004 | 05:56 PM
WYD_TRKR's Avatar
How many of you are using the New C&L Intake Plenum and Phenolic Spacer and have had to retune your chip, as your Air/Fuel ratio's have Leaned out, verses using the stock Plenum?? Any and all opinions would be appreciated! Thanks guy's!
Old Oct 22, 2004 | 06:49 PM
00Bolt's Avatar
i just installed the C&L plenum and phenolic spacer yesterday and Im headed to dyno with A/F graph tomorrow.....
but i also installed 2.8 upper and full exhaust at same time.... but ill be posting results
Old Oct 22, 2004 | 07:41 PM
WideOpen03SVT's Avatar
I'm curious myself as to the answer. I have a C&L plenum coming along with an Accufab TB. My truck is still stock though. Pulley and chip are coming very soon but not before the plenum and tb are on.
Old Oct 22, 2004 | 08:16 PM
cpeapea's Avatar
i think your a/f will be fine, as the added air coming in is still flowing across them maf. unless your maf was pegged the computer should be able to compensate through reading the voltage increase. or maybe im wrong and it doesnt hurt to get it checked on the dyno.
Old Oct 31, 2004 | 09:07 AM
WYD_TRKR's Avatar
Re: C & L Intake Plenum & Tuning????
[/QUOTE]
Well guy's I took the plung today and installed my new C & L "Cast Aluminum" Plenum and a Phenolic Spacer kit. There is definitely a Huge difference in the size of this plenum, verses the stock one. I took the Lightning out for a spin after we installed it and I could not believe the responsiveness of just this simple 45 minute installation mod.
The Lightning felt strong today, all the way through the powerband, verses what it felt like before. Overall drivability is definitley better, especially when you let off the accelerator. No more sudden decrease in the throttle release, when taking your foot off the accelerator, but now a steady smooth transition , coming down off acceleration.
No, it was not just that regular seat of the pants feeling, as you know this Plenum is on there. I will take it into the Dyno in a couple of weeks, as soon as I get a few more things tweaked on this vehicle, to see what HP Number and TQ I picked up here. I am thinking with the Accufab Throttle Body, being on there from before installing this New Plenum & Spacer Kit, that I must have picked up at least another 15 horsepower. We will see.
Old Oct 31, 2004 | 10:40 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
C&L makes/made a billet intake?
Old Oct 31, 2004 | 10:46 AM
RAMAIRSVT's Avatar
well... dyno result???
WYD_TRKR's Avatar
Thumbs up
Yes Bob, they sure do and best part is, you know it is installed on the vehicle to.......
Check it out here:
http://www.cnlperformance.com/truckintake.html
Flow Chart Testing:
Intake Configuration Flow Rate % Increase Over Stock
Stock Plenum/TB 850 CFM Baseline
Stock Plenum/Single Blade TB 943 CFM 10.9% Increase
C&L Plenum/Stock TB 970 CFM 14% Increase
C&L Plenum/Single Blade TB 1103 CFM 29.8% Increase
Old Oct 31, 2004 | 10:48 AM
WYD_TRKR's Avatar
00Bolt, how did the Dyno go????
Old Oct 31, 2004 | 11:41 AM
MISTERgadget's Avatar
It's cast aluminum not billet.
Old Oct 31, 2004 | 11:48 AM
WYD_TRKR's Avatar
"Cast Aluminum" is correct, thanks as I just corrected the Typo!
Old Nov 1, 2004 | 09:39 AM
chimshady1's Avatar
Electric fan,race fuel,C&l power tube=31 rwhp for me
