Back plug removal
Old Oct 30, 2004 | 12:08 PM
HardwareMan's Avatar
Registered User
Back plug removal
what do I need to remove the very last plug on either side of the engine? I can not get to them w/ the tools I have. Any tips on the removal of these two nasty plugs would help.. Plug changes on these things are a pain in the ****...
Old Oct 30, 2004 | 12:21 PM
SLVRLTNG's Avatar
I just use a 2" 1/4 drive extension with a 7mm socket. You can reach in and set the socket on top of the bolt then reach in with a ratchet and plug it into the extension.....takes some patience the first time or two grasshoppa............
edit:that's for the coil pack bolt...
for the plug you need a couple of 6" extensions, a couple of 3" and a swivel. You'll need to assemble a combination of extensions with the swivel, drop down the hole and then use a couple more extensions on the ratchet.....confused???
Old Oct 30, 2004 | 12:28 PM
Registered User
Confused Yes. The coil pack I can get I just dont know the tools for the plugs. Yes confused!
Old Oct 30, 2004 | 12:33 PM
SLVRLTNG's Avatar
hold on a few minutes, I'll get you a pic....JR
you may or not need another 3" ext on the spark plug socket..The 3rd 6" extension on the ratchet end is optional as well
hope this helps.....JR
Old Oct 30, 2004 | 01:04 PM
FASTRNU's Avatar
Go to your local auto parts and buy an extra long spark plug socket. I got one and it made a huge difference in the ease and amount of time the job takes. They are not expensive unless you purchase a name brand like Snap-on for about $60. Here is what I'm talking about so you get an idea.
http://buy1.snapon.com/catalog/pro_d...re&dir=catalog
Old Oct 30, 2004 | 05:16 PM
chiz's Avatar
Mickey_shouse
good god
glad i did it with the s/c off, lol
Old Oct 30, 2004 | 06:45 PM
Registered User
Sheet! I stripped off one of the coil pack bolts in the intake..Any suggestions. It is the first one on the right side looking back!Arghhhhhhhhhhhhhhh
Old Oct 30, 2004 | 08:13 PM
goatheady's Avatar
I also Snap On extra long socket, works like a charm.
The Ghead.
Old Oct 30, 2004 | 09:50 PM
Blown347Hatch's Avatar
Well HardwareMan, you're the expert. You have a choice of helicoil, or if the boss is thick enough, tap the next size larger thread into it.
As an aside, HardwareMan, you must refrain from tightening these little suckers as if they were 1/2 inch grade 8 bolts.
(JK)
