Boost Actuator - working correctly ??
Old Oct 29, 2004 | 04:37 PM
00Bolt's Avatar
just took a pic of my boost actuator with engine off and then again with it on....
im desperatly trying to find why I have low boost and no power... well, have power... just short power... right now im seeing 10psi when I should be around 14-16
does this seem right? i dont really know what its supposed to do
Old Oct 29, 2004 | 04:44 PM
l-menace's Avatar
ONLY THING TO DO is take it off and adjust it to make sure the valve is completely closed.
Also, is the gasket leaking?
Did you over tighten it and warp the casing (very doubtful)
Old Oct 29, 2004 | 04:49 PM
00Bolt's Avatar
iv never touched it before... SC went off and got ported maybe it got bumped in shipping... but iv never done anything to it...
had a thought... i used to have a boost bypass kit on truck when I bought it... found out it was installed wrong... i took it off and am now back to stock... forgot to ever do it again... could that be a problem??? should I install one of those again?? would that cause me to lose 4+ lbs boost??
Old Oct 29, 2004 | 05:15 PM
brahmus's Avatar
no the bypass only "bypasses" boost when no load is on the engine. At WOT it is closed shut and all boost is forced to the cylinders.
Old Oct 29, 2004 | 05:42 PM
12leavu's Avatar
Re: Boost Actuator - working correctly ??
[QUOTE]Originally posted by 00Bolt
[B]
I hope you have those labeled backwards, because the black "tab" is supposed to be resting on the set screw when the engine is off. When you crank the truck it should rise, then close back down to the set screw while under throttle.
Old Oct 29, 2004 | 05:45 PM
00Bolt's Avatar
opps, ya thats backwards... i just checked and that black thing is on the screw right now and engine is off....
i labeled them backwards
Old Oct 29, 2004 | 05:50 PM
00Bolt's Avatar
damn i was excited... i thought that could have been problem... but i just mislabeled the picture...
to confirm it... i installed a new boost gauge today... brand spaken new... and still only about 10psi at WOT
12leavu's Avatar
I would unplug the electrical connection. leave the vacuum lines in there stock position. it will not throw a hard enough code to cause any problems. I had my "boost bypass" hooked up wrong at one time, and it was causing me to lose 2psi. at wot.
Old Oct 29, 2004 | 05:53 PM
00Bolt's Avatar
i just installed a new boost gauge and did just that... i unplugged the plug and test drove it..... 10psi
Old Oct 29, 2004 | 05:56 PM
12leavu's Avatar
check your email.
