Calling Johnny Lightning Performance..
..just thought I'd let you know that the bracket you guys send for holding the flywheel when installing a pulley works absolutely perfect for holding the waterpump pulley in order to remove the fan. If you look on a truck with a pulley installed (not the factory setup) you will see what I mean.
-Sly
-Sly
How did the install of the electric fans go when u finaly got the clutch off. I loved my flex-a-lites on my 97 and i took them back off before it traded them in. I might put them on the L but worried bout how strong the bracket they send with the kit is that holds the intercooler reservior. Let me know how urs goes.
So far it's doing good. Only thing I questioned is that each fan is rated at 1250cfm thus a total of 2500cfm and I wasn't sure if it would be enough to cool the engine but the gauge stays right where it used to before the install, unless the gauges aren't accurate like the FBody cars?? I'll get pics soon after I get a new digi cam. Total expenses out of pocket was $120
-Sly
-Sly
Originally posted by LightningTuner
You're very welcome. I designed that tool back in 99
. Should have patented it, but oh well.
-Sly
Hey, I'm pretty proud of that little tool, I think it's one of my coolest inventions. Ford had a tool to lock the motor for the Lightning; it involved pulling the starter and putting a dummy toothed tool in place. It was a major PITA. When I designed the cageless lower pulley, it was a bear getting the stocker off my 99. When I did the first install of our pulley on a customer truck, I spent about a half day making up all sorts of different tools to lock the motor without pulling that damn starter.
Sorry to hijack a "Thank You" thread, its just that the BS is getting thick here.
joe
Originally posted by 02Thunder
You are gonna sit here and tell people that YOU DESIGNED the cageless lower crank pulley? Wow, its getting deep in here. There were companies making crank pulleys for vehicles before you and I were even born Sal. Gimme a break.
joe
joe
You new guys really should brush up on your Lightning history
I got your new guy, hangin right here.
The cageless crank pulley was created by ASP. You merely supplied them the stock piece to spec off of.
I think I am gonna take credit for designing the the short radio antenna on my truck. Its the same theory, I took the existing piece, made a new one, and installed it. Sure other people have made these before, but mine was different, and I put a JM on the end of the SKU #.
Oh, and you should stop whorin around in other peoples threads, it was directed to JLP not Sal.
