15 inch wheels
Old Oct 24, 2004 | 02:46 AM
TheGoaT's Avatar
15 inch wheels
ok I just spent like 2 hours with our friend the search button, and I cant find anyone running a 15 inch rim other than a bogart. Does ANYONE know of any other 15 inch rim that will fit our trucks? Preferly something I can use on the street.
Old Oct 24, 2004 | 09:58 AM
Grimace's Avatar
Have you ground down the calipers yet? I thought that was why 15 inch rims couldn't be used.
Old Oct 24, 2004 | 11:36 PM
TheGoaT's Avatar
yes I plan to grind down my calipers, I just dont want to spend the money on bogarts, I'm looking for something cheaper.
Old Oct 24, 2004 | 11:46 PM
Grimace's Avatar
Don't you have mickey classic 2's? They come in 15 inch and look badass. I am actually gonna get a 16 inch to run at the track.
Old Oct 24, 2004 | 11:53 PM
TheGoaT's Avatar
yes but they dont make the 15s in our bolt pattern.
Old Oct 25, 2004 | 09:10 AM
Grimace's Avatar
Ahh. What is the actual bolt pattern you bought? Someone said it was 5 on 5.5, someone else said it was smaller.
Old Oct 25, 2004 | 09:44 AM
halcyon's Avatar
I thought it was like 5 X 135mm.......
Old Oct 25, 2004 | 10:22 AM
TheGoaT's Avatar
correct.
Old Oct 25, 2004 | 10:34 AM
Grimace's Avatar
Ok, 5x135 it is. Thanks guys.
Old Oct 26, 2004 | 11:19 AM
93whitelightnin's Avatar
Re: 15 inch wheels
http://www.diamondracingwheels.com/AvengerSeries.htm
For the money, these simply can't be beat. I use to run them on mine.
Old Oct 26, 2004 | 02:28 PM
KB ZILLA's Avatar
Re: Re: 15 inch wheels
Thanks for the Link
Old Oct 26, 2004 | 06:02 PM
Casey02L's Avatar
How much grinding did you have to do so they would fit?
Old Oct 26, 2004 | 06:27 PM
NoSuprise's Avatar
Casey02l,
I tried the Diamond 15" steel wheels on my 2000L.
Ground the hell out of the calipers, moved the caliper backing plate 1/8 inch, used 3/16" wheel spacers and the diamond wheels never fit!
Threw them away and purchased a set of 15" Bogards.
Remember most of the drag wheels are not DOT approved
for the street.
NoSurprise
Old Nov 8, 2004 | 02:06 AM
TheGoaT's Avatar
I take it you ran them on your 93? So do you know if they will fit on a gen2?
Old Nov 8, 2004 | 11:03 AM
Re: Re: Re: 15 inch wheels
I have no idea.
