specific traction bar question
Old Nov 8, 2004 | 10:32 AM
max mitchell's Avatar
Yes, I've read a million traction bar posts already. My question is specific. I want the Rancho/LFP/JLP type bars. I understand that some think the LFPs have heavier mounts. My L is a 2004, so I'm asking this of 2003/2004 owners with the taller stance.
I'm going to run the factory rear end height and exhaust and I want the best bars THAT WON'T COME CLOSE TO HITTING THE EXHAUST and THAT DON'T HANG DOWN TO FAR AND SCRAPE. Is this possible and what do you recommend.
Old Nov 8, 2004 | 11:04 AM
LightningTuner's Avatar
I have gotten these bars from both JLP and LFP. The rear brackets hang down the same distance. No matter which setup you use, you won't have a scraping issue, they don't stick down that far. The LFP brackets are definitely much thicker. I can't really comment on where the bars sit in relation to exhaust, because I have an older design setup in which the front brackets were much lower than the frame. I believe all vendors have since raised the front mount, but I'd suspect that brings the bars a little closer to the exhaust. Hope this helps.
