For Those Running E.T. streets
Just want to know what you guys think of the E.T. streets if your running them. Also what kind of 60fts are you seeing on them. Considering purchasing a pair.
Thanks in advance
Eric
Thanks in advance
Eric
ET Streets
I bought a set last year and they are a vast improvement over the F-1's. Playing with tire pressure (if you are at the track) will also help your 60's. I bought a set of Hoosiers this spring and am really impressed with how they hook up. For all out traction, the Hoosiers are better, but for street use (states that require some sort of tread) the ET's definately make a difference. I haven't hit the strip with either (500 mile round trip to the closest strip) but a quick glance in the rear view mirror lets you know how you are hooking up.
Mark
Mark
Being you have a 2000 with 355 gears the et streets will be a good choice.the 26 inch diameter will act like you have 373 gears .I had them and i got 1.6 60fts.But when i went over 400 hp to the wheels i had a hard time hooking.I now have 28 inch hoosier qtps.they work great.
