What Temp Should I Start To Use The Winter Program????
Old Oct 20, 2004 | 01:56 PM
moshe's Avatar
Old Oct 20, 2004 | 02:27 PM
wydopnthrtl's Avatar
If your going WOT I'd suggest switching it at about the 60F mark.
Rich
Old Oct 20, 2004 | 02:33 PM
VTSVT's Avatar
Yep, JDM told me 60F. I guess technically it depends on exactly what your tune is but the tuners all probably have around 60 in mind.
Old Oct 20, 2004 | 03:26 PM
SVT_KY's Avatar
If you don't do WOT blasts, the computer should correct
just fine for the colder air ... Isn't that what a MAF is for?
I never understood "wasting" a tune on valuable chip
for a "winter" tune if you're never gonna use the fuel
tables.
Am I missing something?
Old Oct 20, 2004 | 03:51 PM
VTSVT's Avatar
my truck goes WOT at least everytime I take it out, unless of course its raining/snowing.
Old Oct 20, 2004 | 06:51 PM
QWIK 150's Avatar
Or run high octane 110+ for short burst. Blowing plugs result in 30 degree weather and 93 octane at 18 degrees timing.
Old Oct 20, 2004 | 08:18 PM
~nightcrawler~'s Avatar
So most of the risk comes from higher boost at higher timing right? So if you normally run like a 6# at 18 degrees in summer then if you bump down to a 4# and 16 degress during the winter should you be ok?
Or is it the fuel mixture? Doesn't the open loop normally add fuel for the cooler/denser air? Should you add more fuel to the closed loop during the winter also?
Old Oct 25, 2004 | 03:25 PM
TTT
