fuel gauge
Old Oct 16, 2004 | 01:12 PM
Svtjedi's Avatar
fuel gauge
bout the last 7 outa the last 10 times i filled up my gauge dosnt register the new fuel load until i shut the vehicle off again and then it will be fine on the next startup,...anyone else with this issue?
Old Oct 17, 2004 | 10:39 AM
Svtjedi's Avatar
ok,...so i guess i will ignore it and see if it goes away........
Old Oct 17, 2004 | 01:02 PM
clonetek's Avatar
Re: fuel gauge
Are you filling up with the truck running? That could be your problem. You aren't supposed to do that.
Old Oct 17, 2004 | 01:07 PM
Fast Gator's Avatar
The fuel gauge will not read the addition fuel until the truck is shut off and restarted. Iam almost willing to bet, thats its a federal law that all vehicles should be shut off when refueling.
This is a common issue with self-serve stations.
Besides the possible explosion from the fumes, why would anyone fuel a vehicle thats running?
Old Oct 17, 2004 | 02:50 PM
Svtjedi's Avatar
ok my bad explaining it,..no i have the truck turned off while fueling and after the first restart 70% of the time it isnt registering until i shut off and start again.
sorry bout the mixup and thanks for even thinking about it.
i have been all thru my ford dvd and i come up empty for a clue
Old Oct 17, 2004 | 04:07 PM
Fast Gator's Avatar
Well if the truck is shut off and restarted and still refuses to give a reading of the addition fuel, then you must have the float sticking. Don't know of an easy fix without dropping the tank. Don't know what could be hitting the float/sending unit........sounds like a bad unit , maybe
Old Oct 17, 2004 | 04:18 PM
01 XLT Sport's Avatar
How much fuel is in the tank BEFORE you fuel? I don’t remember exactly but if you are only adding about a ¼ tank of fuel it will not register right away on the gauge.
Old Oct 17, 2004 | 06:17 PM
Silver Arrow's Avatar
I believe that if you fill up with less than 8 gallons. The fuel gauge does not read full immediately upon startup, but will rise to full over a period of time. If you fill up with more than 8 gallons, then the fuel gauge will read full when started.
This is what I have experienced with my 2002 Lightning.
Old Oct 17, 2004 | 09:56 PM
Svtjedi's Avatar
I normally stop between a 1/4 and when the light comes on at almost empty,..kind of interesting we had a story here in fla about shell having a problem where some peoples fuel gauge quit working after a fill at their pumps but supposedly was fixed months ago now and i only stopped at shell once a while back, usually get the 93 amoco.
count my blessings and wait it out and see, been real lucky and had none of the typical problems some of you have.
Old Oct 18, 2004 | 04:42 AM
Lightning Rod's Avatar
The manual says not to fill up with the truck running or the guage will be off.
Old Oct 18, 2004 | 05:41 AM
afchad's Avatar
SVTJEDI,
I have never heard of anyone else having this problem until I read this post. It happened to me during a two month period three times. The truck was turned off and each time I filled over half the tank. Turn the truck back on...no register...turn it off and back on again...then it registers. Was as confused as you are. No problems since though. Wierd
