Need to get factory radio out
Old Oct 16, 2004 | 11:00 AM
Jkstang78's Avatar
How do I do this. what is the best way. I do not have the tool that fits in the 4 little holes. Can I use a very small screw driver.
Old Oct 16, 2004 | 11:14 AM
54Triton's Avatar
the tool is the easiest way to get it out.....but, i couldn't find mine one time so i used 4 long and skinny nails. I just stuck one in each hole and pushed to the right or left (can't remember) and pulled out on the radio...helpful hint...do one side at a time and have someone pull out on the radio while you prise on it. Hope this helps.
Old Oct 16, 2004 | 11:17 AM
Herb101's Avatar
If you go to most major auto chain store, you can pick up the correct tools for about $6 -$9 bucks. There is not much to them - tapered point, notch cut close to the point, 'finger pull' ring on the other end. All that they do is collapse a plate spring in each location that holds the radio into the dash housing. You could probably do the same thing with a coat hanger stuck in each hole. The risk if scarring up the radio and dash may be higher though - your call.
Herb
Old Oct 16, 2004 | 11:20 AM
KB ZILLA's Avatar
Wal-Mart has the Ford radio removal tools for $3.28.....Everyday
Old Oct 16, 2004 | 11:28 AM
fastfordf150's Avatar
Just bend a wire coat hanger. Cut off two lengths, bend to U-shaped pieces, press them in the holes and pull.
Old Oct 16, 2004 | 11:59 AM
ShockTherapy's Avatar
That's exactly how I did mine.
Old Oct 16, 2004 | 12:15 PM
Jkstang78's Avatar
Thanks guys I got it out, and I was able to hook up my New Xm radio modulator.
Old Oct 16, 2004 | 01:34 PM
eposey's Avatar
I used coat hangers too
Old Oct 16, 2004 | 02:23 PM
01RedS'Crew's Avatar
Re: Need to get factory radio out
^^what he said^^
