Expedition Overhead Console
Old Jul 1, 2006 | 02:12 PM
  #46
Grimace's Avatar
Mine is done. Here are some pics of it installed.
Everything is wired up, except the window switches. They are next. The hvac is functional, and was a real pita to install. Had to run vacuum lines up the passenger a-pillar to make the mode selector work.
Old Jul 1, 2006 | 08:30 PM
  #47
MISTERgadget's Avatar
are you using the L's trip computer or the expy one?
Old Jul 2, 2006 | 09:05 AM
  #48
Grimace's Avatar
Trip computer? I have the stock L temp display up there, I don't have a trip computer. I just modified the expy overhead to fit my display.
Old Jul 2, 2006 | 12:38 PM
  #49
could you show me that more in detail? a couple pictures of that area up close would help me out alot.
Old Jul 2, 2006 | 01:23 PM
  #50
Grimace's Avatar
Sure, I don't have a ton of pics, but I have one of the back with the display out, and a pic of the front with the display in. It didn't fit worth a crap, so I covered the L display with thin tape, and set it in place in the console. I had to trim a little off of the sides to make it fit right, and then secured it with duct tape temporarily. Then I turned the console over so I could fill the gaps with bondo. I used a scribe to trim around the display while the bondo was still a little plyable. Then I let is set for an hour or so and popped the display out. Then I just sanded and fit the display until it looked right. Then I painted it.
Hope this helps.
Old Jul 8, 2006 | 02:58 PM
  #51
speed3198's Avatar
roof attachment
hey grimace, can you tell us how you hung the support bracket from the roof?
I have a 99 L and havent taken the headliner down yet.
Old Jul 8, 2006 | 02:59 PM
  #52
speed3198's Avatar
you can pm me, since I cant pm you. thanks
Old Nov 19, 2012 | 11:07 PM
  #53
rod1220gt's Avatar
Originally Posted by Krix330cic(NJ)
Mine - 7" Accell Widescreen w/fiberglass enclosure.
NO it doesnt block the rear view, and NO it does not strain your neck to look at.
This setup is now in Vin's (Badazz514) truck.
Hey do you still have this overhead console in your truck?
Old Nov 20, 2012 | 05:15 AM
  #54
Veteran: Army
IIRC he sold the truck about a year or two after he posted that...
Old Nov 21, 2012 | 05:21 PM
  #55
rod1220gt's Avatar
I wonder if the other guy who used the same set up has his still.
Old Nov 23, 2012 | 07:30 AM
  #56
Veteran: Army
I doubt it, unless he's changed his screen name when the Lightning crowd migrated...
