guess my ET
Old Oct 7, 2004 | 06:59 PM
00Bolt's Avatar
guess my ET
i think i made a message like this about a week or so ago, but didnt get much response... and since then, Iv bought even more stuff. I should have everything installed and reprogram by next weekend... then Im gonna hit the track alot this fall for some practice...
but with these mods, about how what do you think is reasonable in the 1/4
Ported Eaton
Full Exhaust (kooks, magnaflow, cats, xpipe)
4lb Lower
2.8 Upper
Idler Bracket
SCT Dyno Tune
EFan
JLP Ram Air
C+L Plenum
Phenolic Spacer
FTVB
Slicks
90mm
Accufab
Rancho Traction Bars
Old Oct 7, 2004 | 07:15 PM
00Bolt's Avatar
Old Oct 7, 2004 | 07:56 PM
ShockTherapy's Avatar
Once all those mods are on and tuned...
12.1@112 with a 1.8 60'
11.999 @ 111 with a 1.75 60'
Old Oct 7, 2004 | 09:59 PM
tallimeca's Avatar
hmmm
Those numbers might be a bit generous. The texas heat may be against you but unless you squeeze a low 1.7 60, you should be in the low 12's all day. The perfect launch and perfect air may crack 11's. Good luck, either way, that's still pretty damn fast for some bolt on's.
I've got similar mods minus the upper, my goal is 12.5 out of my 2000. As long as my truck gets straightened out, hopefully i'll see it JDM day. My best is a 12.71. That's with a 1.86 60.
