supercharger pulley
Old Sep 19, 2004 | 01:48 AM
BLULIGHNTING's Avatar
supercharger pulley
Im considering buying a pulley to add 8 lbs to my 02 lightning. I need to know if there is anything I need to do besides the gauge and belt change. Will it do any damage doubling the boost? Will I need to do any other mods to make my truck handle it as far as air,fuel, etc. Any help would be welcome. Thanks
Old Sep 19, 2004 | 02:19 AM
Grandmastr's Avatar
8lbs is too much
overworking the eaton=more heat=less hp
go with a 4lber, get a chip reburn for the computer to see the pulley and compensate the air/fuel ratio for it
no chip with a 4lber, your going to blow the engine
Old Sep 19, 2004 | 03:07 AM
WaveBlaster785's Avatar
Originally posted by Grandmastr
no chip with a 4lber, your going to blow the engine [/B]
False.
My friend has been running a 4lber for over 2 years now with no chip. Of course the performance isn't anywhere near what it would be with a chip. But I'm not sure he cares because he didn't put a window in his block yet.
Old Sep 19, 2004 | 08:02 PM
hey waveblaster
What are you referring to about putting a window in his block?
Old Sep 19, 2004 | 08:31 PM
kwilt's Avatar
blowing a hole in it with a rod from to much hp on the stock block
Old Sep 19, 2004 | 09:26 PM
denny0328's Avatar
I'm gonna have to agree with Grandmastr...
Although it might be possible to run a 4# with no chip reburn, it is by no means safe to do so. You do risk the chance of throwing a rod, and the money for a chip reburn now, is ALOT less than the money for a short block later.
-dennis
Old Sep 19, 2004 | 09:42 PM
hp
How much hp will it add with the 4lb and the chip? I need the max I can get. Have someone running their mouth. They made a comment about giving me a 5 car start and it pissed me off!
Old Sep 19, 2004 | 09:45 PM
superfords's Avatar
I say go ahead with the 8lber and no chip on your stock long block.
that way, at least when you do race 'em, as they are passing you your engine will be exploding and maybe they'll get hit by a piece of one of your connecting rods.
if you wound 'em badly enough maybe after the race they won't run their mouth about beating you.
(just kidding)
good luck.
later,
chris
Old Sep 19, 2004 | 09:54 PM
I have no plans on them beating me
Old Sep 19, 2004 | 10:06 PM
Edward Goodell's Avatar
whats more important winning or loosing a race or spending 10 grad for a new motor. i have a single chip 4lb pulley cold air with slicks and i just ran two consistant 12.71 at 106. 8lb pulley is WAY to much. If you want a eight pound pulley put out 10 grand for a new built motor first and then put that eight pounder on.
Old Sep 19, 2004 | 10:07 PM
all help welcome
Thanks for any help gave to me on here. All help welcome. Fortunately for me I have one of guys who knows alot about such things near me. Im going to go to him for help along with the help from everyone here. That guy is Lee Bender of C and L performance. Keep the help coming. More power and more speed.
Old Sep 19, 2004 | 10:14 PM
fast1's Avatar
The only other Lightning owner in town, ran a 8lb lower pulley and a smaller upper pulley. All of this with the Predator 4lb pulley tune. His motor lasted about 2 1/2 weeks. He's not sure what's wrong yet. The motor has a big miss from idle to 3000rpms. He changed the stock plugs, which were fried. But it still has a bad miss. It's at the local SVT dealership getting looked at. He thinks it might have a burnt valve??
