Engine cleaning
Old Sep 14, 2004 | 08:03 PM
XArchAngelX's Avatar
Engine cleaning
Is Sea Foam a good engine cleaning tool?
any advice?
Old Sep 14, 2004 | 11:32 PM
Rob_02Lightning's Avatar
Hows the New L going Bro ?
ALL IS WELL I BET
Yes I think I've heard of many using the Sea Foam.
Unfortunately there are some real bitchy spots to get
to on a L motor, and lots of STUFF blocking the
way to simply do it by hand. BUT) to date I've
yet to take a hose or solvent to mine. I try and do it
the old fashion way with a simply bottle of Armorall
and a rag, it's a MF to get into a lot of area's, but with
a little patience and keeping on top of it often enough,
you can keep the motor looking fine. (Or at least most of it)
GOOD LUCK XAAX
Old Sep 14, 2004 | 11:42 PM
Blown5Pnt4's Avatar
The easy way to do it is this.
get a BIG bottle of armorall wet shine or whatever its called that works for plastics and stuff.
Then Spray EVERYTHING down in it just taking care around battery terminals and things of that nature.
rub it in a lil bit, and shut the hood.
go out for a 20-30min drive
open the hood, and spray down again, rub some more.
Should come out nice and jet black.
Also tip if you have any polished metals, or underhood bling, get this polish called Blue Magic, I showed Rob how well it works.
