oil sep. ?
Old Aug 28, 2004 | 09:18 PM
00rsvtl's Avatar
Question oil spe.?
just installed the lfp oil sep, on the pass.side.wooooooooooow works great .have been looking for oil sep. setup for the drivers side.have not been able to find one.any one know where i can find one.was looking for a set up to just "drop in" and not have to do a bunch of cut up work.thanx in advance
Old Aug 29, 2004 | 12:15 AM
EZGZ's Avatar
Here is what I use.
http://lightning-enterprise.com/pcv.html
Old Aug 29, 2004 | 01:56 AM
echo5oscar's Avatar
I just capped off all the connections and put breathers on both valve covers. Works great and you don't get boost bleeding back into the passanger side valve cover to pressurize it.
Old Aug 29, 2004 | 10:27 AM
00rsvtl's Avatar
i have had the pcv kit on the truck since i have owned it.to me it seems to be junk.never stopped the oil.have seen the breather option.that would require some retuning correct?
Old Aug 29, 2004 | 03:00 PM
RED 92's Avatar
https://www.f150online.com/forums/sh...71#post1403771
ditto that, add a 3rd breather to your oil filler.
Old Aug 29, 2004 | 03:17 PM
moshe's Avatar
were did u get does breather caps???
Old Aug 29, 2004 | 07:48 PM
echo5oscar's Avatar
I bought everything I used from Pep Boys, but the breathers RED 92 used look better than the ones I have. I didn't have my computer reflashed for this mod, it really isn't changing a whole lot so there shouldn't be a need for a retune. You might see a slight increase in boost, maybe .25 - .5 lbs. sence there isn't any bleeding into the valve cover.
