Cold air vs a c&l95 mass air with Filter
Just got an 02 wondering what i should do for induction the C&l kit is $260 with a filter wich is a 95mm mass air too. Compared to the Air raid intake at $180? Any IDIEAS WHATS BETTER TO DO THANKS SHAWN
I got the C&L 95 along with the inlet tube, installed a lower 4lb pulley, flowmaster cat back, predator tuner, 160 degree thermostat and by-passed WOT bypass. Best time so far in low humidity/temperature is 13.07 was hoping for a high 12 but no luck. The C&L seemed to take a little response away from low end (possibly a good thing considering wheel spin). No complaints so far.
intake.
I personally think that the JLP Ram Air intake is the nicest out for out truck. I just picked up one used. Very clean look and gains are measurable. Price is also reasonable.
Some of the aftermarket intakes such as the C&L and ProM can run into some issues if not tuned correctly. I would make certain that your tuner is familiar with your setup and is aware you have it when burning a program.
