Anyone using the Whipple??
Originally posted by Dale-01L
Im running a 140 which utilizes a Whipple 2300 blower at its core..
I dont think you will find anyone running the Whipple 5.4L blower in the Lightning forum. That would take a ton of customization to make work as the outlet is right into the smog/emissions stuff on the drivers side of the blower...
-Dale
-Dale
one of our guys over on SVTP had one on his HD
key word HAD
it took all sorts of time to get it on right because nothing fit correctly (i.e. would not clear the cab, would not clear the fuel lines and a bunch of other stuff)
well he finaly got it on the truck and it ran great for about a week
then the blower came apart internally, either the bearings failed and boinged up the shaft or the rotors started smashing into eachother, not sure what one
http://svtperformance.com/forums/sho...t=works+blower
here is one
and an other
and thats it, if you want to read them start at the last one ad go up as they are in reverse order
hope this helps you out in one way or another
key word HAD
here is one
and an other
