Metco Idler Pully
Old Aug 16, 2004 | 10:12 PM
03LightninRocks's Avatar
Metco Idler Pully
I received my Metco pully set up today from Tim@Chickenears. I had it installed in about 15 minutes. Great quality and easy to install.
I like it alot better than the previous versian. Thanks Tim for the great service/response........
I won't hesitate to do business with you again. It was a pleasure as usual.
Rocks
Old Aug 16, 2004 | 10:37 PM
Redlightn 02's Avatar
Any pics? and why you like better than the other version.
Old Aug 16, 2004 | 10:57 PM
JeffsLightning's Avatar
The older version bolts to the bottom of the supercharger.. The newer setup looks better and cleaner..
Old Aug 16, 2004 | 11:09 PM
SLVRLTNG's Avatar
here's the "new" version, from Tim also....
Old Aug 17, 2004 | 09:10 AM
Same reason for me. The old version used the corners of the supercharger for mounting. I really didn't feel comfortable with that. It also made it a bit tough routing the hard plastic hose back to the intake. The old one would not work for the KB....which I have now.
The new one uses the factory idler pully bracket.....Nice and clean.
Rocks
Old Aug 17, 2004 | 09:40 AM
Grimace's Avatar
I wonder if the warrantee ****'s would void that setup? It doesn't bolt the the s/c itself, and doesn't put more of a load on the forward bearing, does it? It just makes the belt wrap farther around the pulley. Correct?
Old Aug 17, 2004 | 10:15 AM
Tim Skelton's Avatar
Originally posted by Grimace
I wonder if the warrantee ****'s would void that setup?. . .
In and of itself, it would not seem to be a problem.
But it's useless unless you have aftermarket pullies on -- and those might void the powertrain warranty.
Old Aug 17, 2004 | 02:15 PM
Grimace's Avatar
The reason I ask is I have a gatorback, and it still slips through a shift. I can hear the belt squeal at the peak of the shift. This is something I thought would probably solve that problem.
Old Aug 17, 2004 | 02:27 PM
Stock pulleys?
Old Aug 17, 2004 | 02:52 PM
MaxPower's Avatar
You sure it's not the accessory belt? That is typically the cause of the squeak... If there's more than 1/4" of play on your S/C belt, get a 1/2" shorter one.
Old Aug 17, 2004 | 05:24 PM
Fast Gator's Avatar
Sure glad I waited before thinking of ordering
Have to give the ChickenCoop a call
**FIRST time that ever happened!**
Btw......I understand the warranty ******** @ KB will void the blower warranty for that setup
Old Aug 17, 2004 | 06:33 PM
LightningToGo's Avatar
I concur! I have the idler kit and still get the slight squeak if i let off the throttle real quick right after it shifts.
Old Aug 17, 2004 | 09:30 PM
silverbolt01's Avatar
ditto
Just put mine in yesterday as well, very nice product and
2 thumbs up to TIM@chickenears......
BTW, very nice 01 lightning, looks identical to mine....
Rich
Old Aug 17, 2004 | 09:48 PM
I wondered about that myself. Since it doesn't actually bolt o the blower...it shouldn't affect the warranty. But Kenne Bell seems to look for reasons to blame anything but the blower, if it fails.
I probably wouldn't mention the idler set up if I did seek warranty work from them.
Rocks
Old Aug 18, 2004 | 01:50 AM
Grimace's Avatar
I don't have alot of play in my sc belt, and they are the stock pulleys. I hear it when I am standing on the loud pedal and don't let up for a shift. Could it be a faulty idler pulley for the accessories?
